Why we draw rectangular compnents of a vector?
In summary: This is why vectors are drawn in rectangular form - it makes it easy to manipulate and store the information. In summary, vectors are used to describe motion in more than one dimension, and are represented by their retangular coordinates. These coordinates can be summed together to get the coordinates of the resultant vector, and because the cosine theorem is the simplest when the triangle is rectangular, Pythagora's theorem is also applicable. And because we invented the Gram-Schmidt orthogonalization procedure, we can also use this to separate different inputs.
Aladin
77
Please explain me:what is the main purpose to drawing the rectangular components of a vector and why we draw them
thanks.
Example of where we need vectors is for describing motion in more than one dimension.Horizontal and Vertical are the two main directions we look for when trying to simplify problems and for general analysis.Generally vectorial quantities will be in directions making tedious angles with horizontal and vertical, so we take components of these vectors in two prependicular directions.The direction vector and velocity vector of a projectile motion will be a good practice and will tell you the importance of vectors.
BJ
The retangular coordinates of a vector are scalar numbers. So, if you have a set of vectors and represent each of them by its retangular coordinates, you can sum the scalars in each axis and find the coordinates of the resultant.
Because the cosine theorem is simplest when the triangle is rectangular.We then have the celebrated Pythagora's theorem to play with.
And because we invented the Gram-Schmidt orthogonalization procedure.
Daniel.
Not necessarily. Sometimes it is usefull to use polar coordinates. In many cases equations looks easier for the ortogonal Decart system, but sometimes they are not.
Or, one may say, it is because the empty space-time is flat.
sorry I could not understant.please explain with a example.
thank you.
Daniel.
Disclaimer:
I did not invent the procedure; Gram and Schmidt did.
An example:
if we want to find out how a electromagnetic wave propagates in a rectangular waveguide, we will use Cartesian (Decart) coordinates. If we want to solve the problem for cylindrical waveguide. we will use cylindrical coordinates. For sphericaly symmetric cases one may find that it is better to use spheical coordinates, where vectror is tedermined by its magnitude and two angles.
The main idea of this manipulations is to separate different inputs. We know, for example, that a gravition force depend only on distance between two points and is along the line which connects them. Thus we can expect that equations of motion may look simpler if we choose one coordinate as the distance between two points.
thanks.
The purpose is to be able to rewrite a vector equation in terms of a set of scalar equations so as to be able to solve for the components of the required vectors.
Remember, a vector has as many components as the space it lives in, so to completely specify a vector in n dimensions, you must specify n (linearly) independent things about it.
1. Why do we use rectangular components to represent vectors?
Rectangular components are used to represent vectors because it simplifies vector operations and calculations. By breaking down a vector into its horizontal and vertical components, we can use basic trigonometry to find the magnitude and direction of the vector.
2. Can't we just represent vectors using their magnitude and direction?
While it is possible to represent vectors using just their magnitude and direction, this method can be less precise and more difficult to work with. Rectangular components provide a more accurate and efficient way to perform vector operations.
3. How do we determine the x and y components of a vector?
The x and y components of a vector can be determined by using the trigonometric functions sine and cosine. The magnitude of the vector is multiplied by the cosine of the angle to find the x component, and multiplied by the sine of the angle to find the y component.
4. Are there any other ways to represent vectors?
Yes, apart from rectangular components, vectors can also be represented using polar coordinates, which involve using the magnitude and direction of the vector to find its components. Additionally, vectors can also be represented using matrices or as a linear combination of basis vectors.
5. Why are rectangular components important in physics and engineering?
Rectangular components are crucial in physics and engineering because they allow us to analyze and solve problems involving forces, motion, and other physical quantities. They also make it easier to break down complex systems into simpler components for analysis and calculations.
  • Linear and Abstract Algebra
  • Atomic and Condensed Matter
  • Other Physics Topics
