Calculating Electron Movement in a Television Picture Tube
  • Thread starter Thread starter z_sharp
    Television
In a television picture tube, electrons are accelerated through a vacuum by high voltage, and the question arises whether they can move upwards against gravity if the TV is laid on its back. To keep an electron stationary, the electric field must balance the gravitational force acting on it. The relevant equations include E = mg/q for calculating the electric field and E = V/d for determining the voltage across a distance of 20 cm. To solve for the charge (q) of the electron, one should refer to a table of physical constants. Understanding these principles is essential for calculating the necessary voltage to counteract gravity.
z_sharp
Hey all, I'm working on this question for my homework. Can someone please help me get it under control, I read it and all I can say is 'huh'?
In a television picture tube, electrons are accelerated by thousands of volts through a vacuum. If a television set were laid on its back, would electrons be able to move upwards against the force of gravity? What potential difference, acting over a distance of 20 cm, would be needed to balance the downward force of gravity so that the electron would remain stationary? Assume that the electric field is uniform.
Thanks everyone
If there is a voltage difference, there must be an electric field. That field is what accelerates particles, and balances gravity (in your question).
What magnitude electrical field would it take to balance the weight (on earth) of an electron?
What would the voltage be over a 20cm gap with that electric field?
Ok I think I have the right idea here...
mg=qE
E = mg/q
E = V/d
Now I have values for g, m, d. How do I find q, so I can do the first part of the question?
You look in your table of physical constants to find the charge of an electron.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
