PeterDonis said:
I think you are assuming a lot about the properties that consciousness must have. Do you have an actual theory of consciousness to back this up (or a reference to one), or is it just your opinion?
This one is based on two direct observations of your own conscious state. First, when you are conscious, are you conscious of information - a memory, an image, etc? When you are conscious, are you conscious of more than one bit of information? The experiment can be tricky because you may be conscious of a recently created memory that symbolizes more than you are really conscious of in one instant - but even then, it is more than a few bits.
PeterDonis said:
So is the entire universe. If you're going to take this approach, there are no separate objects at all; there is just one universal quantum state. Again, do you have an actual theory of consciousness (or a reference to one) that explains how it works if there are no separate objects but just one universal quantum state? Or is it just your opinion that all this makes sense?
I am not talking about a "universal quantum state". I am talking about information processing devices that process information in a purposeful way as viewed by our species. In a broad sense, the entire universe is technically an information processing device - but in this thread we are limiting ourselves to brains and artificial intelligence machines that do something humanly purposeful (in the sense that we readily ascribe a purpose to it) with the information - such as a ECDIS system steering a ship, or a brain assisting an animal to survive.
The specific example I gave was Shor's Algorithm (
http://arxiv.org/abs/quant-ph/9508027v2 ). In that case, scores of qubits are manipulated so that when their states are finally measured, they provide indications of the prime factors of a large composite number. The purpose of that reference was to illustrate that there is something more sophisticated that simple binary states but short of the entire universe - and that it involves the processing of a single elaborate QM state to a purposeful end. There is a stage in that processing when the entire problem is in a single QM state - where any measurement will effect the entire system - not just the qubit being measured. This is very different from a common 64-bit register where the state of each bit remains entirely local to its hardware device.
Another example is Grover's Algorithm (
http://arxiv.org/abs/quant-ph/9605043 ). A device designed for Grover's Algorithm can search through many possibilities looking for a match. This is much more likely the kind of algorithm that would be biologically useful.
The OP asked the question about self-awareness and consciousness in an AI device. A "self-awareness" independent of consciousness can be designed into an AI machine with little effort as I described above. "Consciousness" can also be quickly addressed - but not quickly designed in. With direct observations of our own experience of consciousness, we can discover some of the physical requirements for our consciousness such as:
* It must be supported by a single state as described above;
* It can effect our behavior - otherwise we would not ever discuss "consciousness"; and
* The type of information we are conscious of is heavily processed - we're not conscious of the individual contributions of each rod and cone in our retina or each tone measurement in our ears.
Laboratory results can also contribute to our list of requirements - though, so far, less directly.
As far as "theory of consciousness" is concerned, there is a difference between the philosophical treatment of consciousness and the physical treatment of it. Even if we had a "theory of apples", it would not help us understand apples. Instead, we can examine the apple and discover all sorts of physical charateristics of apples and perhaps at a certain point determine if an artificially designed apple had all the characteristics we think we need to qualify as an apple.
I can taste an apple and tell you whether is has an apple flavor. You can then repeat the experiment and decide if you agree. Those three observations about consciousness are my own observations - but you or anyone else can repeat the observation for yourself.
