Will separation of variables work in solving this PDE?
AxiomOfChoice
As part of the solution to a HW problem of mine, I have to solve the PDE
<br /> p_t = -vk^2 p - k \delta p_k,<br />
where p = p(k,t) and v,\delta are known constants.
I tried to look for a solution of the form p(k,t) = K(k)T(t) and found one, but I'm not sure if I need to sum/integrate over my arbitrary constant.
Separation of variables gave me the solution
<br /> p(k,t) = A_0 e^{-ct} k^{c/\delta} e^{-vk^2/2\delta},<br />
where c is the constant one gets from the separation of variables and A_0 is a constant of integration. But I tried solving the PDE in Mathematica, and got a different solution:
<br /> p(k,t) = A_0(t-(\log k)/\delta) e^{-vk^2/2\delta}.<br />
Can someone explain why Mathematica's answer differs from mine? Also, do I need to perform an integration/sum in c to get the most general solution? I've plugged both my solution and Mathematica's in, and they both work, so I'm thinking I have to go another step to get the general solution.
AxiomOfChoice said:
I tried to look for a solution of the form p(x,t) = X(x)T(t) and found one, but I'm not sure if I need to sum/integrate over my arbitrary constant.
Show us some details about how you arrived at your solution.
One thing I noticed:
<br /> \log\left(e^{-ct} k^{c/\delta}\right)=-c\left(t-\frac{\log(k)}{\delta}\right)<br />
I'll be happy to. I have a function to go to right now, but I'll be back in a few hours and will type up how I arrived at my separation of variables solution.
Ok. So, on to my separation of variables calculations. Note that I have also corrected a typo in my original post, replacing some x's with k's. Writing p(k,t) = K(k)T(t) and plugging into the PDE, we find (after dividing through on both sides by KT)
<br /> \frac{1}{T} \frac{\partial T}{\partial t} = -v^2 k^2 - k \delta \frac{1}{K} \frac{\partial K}{\partial k}.<br />
The LHS is a function of t only; the RHS a function of k only. So we can (I think) set them both equal to a constant, which I call -c (anticipating that it will be negative). The equation for T becomes
<br /> \frac{d T}{d t} = -c T.<br />
This has the obvious solution T(t) = C_0 e^{-ct}. The equation for K, however, becomes (after canceling the minus sign)
<br /> v^2 k^2 + k \delta \frac{1}{K} \frac{d K}{d k} = c.<br />
This can be rearranged and rewritten as
<br /> \frac{dK}{K} = \left( \frac{c}{k \delta} - v^2 k \right) dk.<br />
Integrating on both sides, we obtain (after combining the two constants we get into one, C^0_1, on the RHS)
<br /> \log K = \frac{c}{\delta} \log k - \frac{v^2 k^2}{2\delta} + C^0_1.<br />
Hence, after exponentiating both sides, we obtain
<br /> K(k) = C_1 k^{c/\delta} \exp \left( -\frac{v^2 k^2}{2\delta} \right).<br />
Now we put them together:
<br /> p(k,t) = K(k)T(t) = A_0 e^{-ct} k^{c/\delta} \exp \left( -\frac{v^2 k^2}{2\delta} \right),<br />
which is what I have listed above. Does anyone see anything wrong with this?
It looks good to me.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
