Can a Longboard Skateboard Be Turned Into a Musical Instrument Using Pipes?
  • Thread starter Thread starter wiznas
    Project Wind
The discussion centers on the feasibility of transforming a longboard skateboard into a musical instrument using pipes that function like flutes. The artist aims to create a deck that produces sound as air passes through, but has encountered challenges with achieving consistent humming while riding. Suggestions include positioning the pipes sideways and incorporating holes or buttons to modify pitch. The artist has had some success with PVC pipes producing sound during rides, indicating potential for the project. Experimentation and adjustments are encouraged to refine the design and achieve the desired musical effect.
wiznas
I am an artist not a physicist, I do very much interactive art though, and as I am a bit geeky, I really love to get some physics tricks involved somehow. People get excited when there are little gizmos going and its just great!
So this project that I am working on has me stumped...I want to create a longboard skateboard deck out of pipes, that would function very much like flutes. As the air passes through, it hums, and the pitch changes depending on where you stand (probably by having a series of holes down the pipe).
Now I have made a few simple whistles and flute-like things, but I am starting to think that's barking up the wrong tree. I can't get them to hum while riding with them; my theory is because they rely on the wind going through such a small area that it gets all turbulent and its easier for the air to just pass over it. I tried making a simply scoop (or a funnel thing) but that didnt help. Butttt...when I was longboarding to my studio with some pieces of pvc, I could deffinately here one of them humming, so I am pretty sure this is possible. Any wisdom would be so much appreciated!
Dan
Dan
Welcome to the PF!
Turn the pipes sideways (so they go side-to-side, not along the long axis of the board).
Can I still have holes on the top to change the pitch?
I don't know enough about the physics of musical instruments to know the answer, but worst case, you could put buttons on top of the board that you could step on to close off the sideways tubes at different lengths. That definitely would change their pitches. Experiment some, eh?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
