Wind Power Generation: Calculating Output from 30mm Turbine
To calculate the power output from a 30mm wind turbine, it's essential to consider the number of coils surrounding the armature and the wind speed. Documentation for specific alternators typically provides output data at various RPMs, which can guide calculations. Built-in regulators in alternators help prevent overdriving by limiting output. Additionally, the gearing between the turbine vanes and the alternator plays a crucial role in efficiency. Understanding these factors will aid in designing effective wind-powered gadgets.
stu1984
I am looking to design a few ‘wind powered’ gadgets, on a very small scale. I am struggling to calculate the power generated from a turbine of about 30mm diameter. I understand that the number of coils surround the armature has an obvious effect on the generation, but was wondering if there was an equation to unable me to calculate the output under certain wind speeds?
cheers
There should be documentatin available to show output at various rpm's for your alternator of choice. Most have built-in regulators to limit that output if the unit is overdriven. The other factor will be your gearing between the vanes and the alternator. In some cases (probably not yours), the vane pitch can be varied as well to maintain a certain speed.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
