Winding number for a point that lies over a closed curve
The discussion revolves around the concept of the winding number, particularly in cases where a point lies directly over a closed curve. Participants explore the implications of this scenario for applications in algorithms related to polygon offsetting and self-intersection classification.
  • One participant questions whether the winding number is undefined when a point lies over the curve, expressing uncertainty about the theoretical consistency of their algorithm for polygon offsetting.
  • Another participant seeks clarification on the terminology used, specifically what is meant by a point being "under" the curve, suggesting a potential misunderstanding related to dimensionality.
  • A participant asserts that if a point is on the path, the winding number around that point is not defined, indicating that established definitions may not apply directly in such cases.
  • There is a suggestion that for practical applications, the classification of points on the path as either inside or outside may depend on the specific use case.
  • A request for examples of invalid loops in the context of self-intersections is made, indicating a need for further clarification on the topic.
Participants express differing views on the definition and applicability of the winding number when a point lies on a curve, with no consensus reached on how to handle such cases.
The discussion highlights limitations in the definitions of winding numbers, particularly regarding points on curves, and the potential need for adjustments based on specific applications.
pigna
The definitions of the winding number, that I have found, do not consider the case in which the point lies over the curve. Is there the winding number undefined ? I'm interested in this issue because I'm writing an algorihm for polygon offsetting that as first step creates a row offset polygon ( generally a non simple polygon with self intersections). Than i have to classify these self-intersection to remove the invalid loops of the row offset curve. I have successfully reach this purpose implementing an algorithm that gives me a value for the winding numbers of these self-intersections ( simply using the summ ω(point,Poly)=∑[θ][/i]), but actually I don't know if this operation is consistent with the theory... I need some clarification about this point and eventually some reference to some papers that address this issue...
I don't know what you mean by saying "the point lies under the curve". The usual definition of winding number is for curves in 2 dimensions, and you compute the winding number about a particular point in the plane. So what does "under" mean in that context? Are you talking "under" in the sense of 3 dimensional space?
what is an invalid loop? example?
thanks for the replies... looks at the pdf in which I clarify what I'm interested in...
If a point is on the path, the winding number of the path around the point is not defined. You may be able to define it appropriately for your particular use, but that would be up to you and how you are going to use it. If you want to rely on established definitions of "winding number", you will need to avoid that situation by changing either the path or the point position.
For many applications, such as determining if a point is inside or outside a simple closed path, it is just a matter of you stating whether points on the path will be considered inside or outside.
  • · Replies 72 ·
12K
  • · Replies 19 ·
