Understanding the Role of Winding and Conductors in Electrical Circuits
  • Thread starter Thread starter kevs926
    Windings
When conductors are wound in electrical components like motors and transformers, they are insulated to prevent short circuits, despite appearing to touch. The insulation thickness varies, with "magnet wire" typically using thin insulation to minimize leakage inductance by allowing closer winding spacing. In some applications, such as spiral-wound heating elements, the wire is not insulated but is held apart by grooves on an insulating former. Wire-wound resistors also prevent turns from touching by embedding the wire in insulating materials. Proper insulation is crucial, especially in multi-layer designs where voltage between layers can be significantly higher.
kevs926
when conductors are wound, they touch each other.
why would the current flow through the spiral path when they can just jump on the next wire??
Are you referring to motors, transformers, and inductors for example?
If so, the wiring in those is insulated.
As mdjensen says, the wires are insulated. Just to add a bit to that -- there are different thicknesses of insulation for "magnet wire", or wire that is being used to wind magnetic components.
The thicknesses are typically called "single build" (the thinnest), "double-build" and "triple build" (pretty thick). You use the thinnest insulation that you can (as long as the voltage insulation rating is high enough for your needs), so that you can space the windings as close together as possible. That helps to lower the "leakage inductance", which is basically a measure of how much magnetic field is not in the magnetic path that you want it to be in.
The wire used in some spiral-wound heating elements is not insulated. In this case, although adjacent turns of wire may look as if they touch, they are in fact held apart in grooves on an electrically insulating heat-resistant former.
The design of wire-wound resistors also avoids the turns touching, and usually the wire is embedded in vitreous enamel, or some other insulating material.
The insulation may not need to be 'too good' betweeen adjacent turns because, for a single layer, the voltage between them will only be Supply Volts / Number of turns. When there are more layers, of course, you can expect much higher volts between layers.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
