Wire 6 LED's to 110v AC: Step-by-Step Guide for Converting Solar Lights
  • Thread starter Thread starter vette505
    Ac Wire
The discussion revolves around converting solar-powered LED garden lights to operate on 110V AC power. The user seeks a straightforward method to connect six LEDs, either in series or parallel, without unnecessary components, emphasizing safety and voltage regulation. Suggestions include using a low-voltage transformer or a double insulated wall-wart to avoid risks associated with high voltage. There is a consensus that a 24V garden lighting system is more appropriate, and clarification is sought on whether the user intends to completely remove the solar component. Overall, the focus is on achieving a safe and effective conversion of the lights for indoor use.
vette505
Hey guys, I've been researching on the internet for some time, and can't seem to find what I'm looking for. I purchased solar powered single LED garden lights yesterday and am going to convert them to be able to plug into an outlet in the house. I've been reading some forums and everybody seems to have a different situation that is a little different than mine, so I thought I'd throw mine out there. I am looking to connect 6 in either series or parrallel - whichever is easier. I don't need a handful of "just in case" components either. Just whatever will get the job done and regulate a safe voltage. The battery that came out of the lights is a 1.2v AAA. Could anybody write a simple schematic for 6 of these, and one for 10 of these? If not that's okay. If so, thanks a million!
I'd like to keep it simple guys!
Get a low voltage transformer and the lights that go with it..
You don't want housepower floating around in your garden.
Where are you planning to use these ?
I agree with Jim, a commonly available 24V garden lighting system is actually the proper route. However can you clarify - you want to remove the battery completely? and not use the solar part of the light?
I am sure the load ( required power ) is very low - you may also get away with a double insulated (important) wall-wart. You can get to a lower voltage than 24V ( maybe 3V) which is still too much to connect directly to the lights you have. You then will need to hack the lights a little to understand really what they need.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
