Why do wire-grid polarizers have a separation less than the wavelength?
  • Thread starter montser
  • Tags
    Grid Wire
In summary: However, for oblique incidence, the reflected wave will no longer be exactly out of phase with the incident wave since the spatial phase progression of the reflected wave will be different. This means that the standing wave won't be as strong and the waves will have different intensities in different directions. Thus, there will be a net transmitted wave that isn't in the direction of the incident wave.In summary, wire-grid polarizers work by reflecting the waves parallel to the wires due to the phase shift caused by the induced electron movement. This causes the forward waves to cancel, while the energy is redirected back towards the source. The wires must be spaced close enough together for this effect to occur, and the symmetry between the incident and forward
montser
I've read about wire-grid polarizers from wikipedia. The article says that waves perpendicular to the wires cannot induce electron movement and hence they pass through with minimal energy loss. On the other hand, waves parallel to the wires are reflected by the wires because electron movement is possible. What I don't understand is two things:
1. why the electron movement doesn't also induce a transmitted wave?
2. why must the wires need to have a separation less than the wavelength?
Thanks
Science news on Phys.org
You need 2. in order for 1. to happen.
Each wire has an 'effective cross section' so that high enough currents will be induced into it for the grid to act like a sheet.
Why just reflection? is because there is 180degree phase shift and the re-radiated wave is of equal amplitude to the incident wave. That means that forward waves will cancel . The energy has to go somewhere, so it goes back the way it came.
what phase shift?between what?and why there is a phase shift?
Thanks for you replay
It's all about so-called Boundary conditions. The E field must be zero at the surface of a perfect conductor (a 'short circuit' therefore no volts) so the wave that is produced by the currents induced in the surface must produce a wave that is in anti-phase with the incident wave. The sum of these waves, in the forward direction is zero.
Having a grid is almost as good as having a continuous conducting surface (for that particular polarisation) as long as the wires are spaced close enough together.
First, thanks for your replay. Now I understand why there is a phase shift. But what I still do not understand is why this re-radiated wave do not cancel also the incident beam? in other word, what breaks the symmetry between the incident and the forward waves?
again thanks
again thanks
With the scattered wave, there is no phase shift between the waves on either side of the grid. Basically the grid behaves like a continuous sheet as described previously and it acts as a new plane wave source. So the waves on either side of the grid only differ in the direction of travel. So on the transmitted side, this means that the spatial phase progression follows that of the incident wave since they both travel in the same direction. But on the reflected side, the scattered wave is traveling in the opposite direction (if we assume normal incidence) as the incident wave. Thus, the phase progression in space is different between the two. For example, the incident wave may be something like
[tex] \mathbf{E}_{inc} \sim \cos (kx-\omega t) [/tex]
While the reflected wave is,
[tex] \mathbf{E}_{ref} \sim \cos (-kx-\omega t) = \cos (kx+\omega t)[/tex]
So you can see that for a given time t that the two will interfere constructively (take the case of t = n*2\pi for an easy comparison).
For normal incidence, there will be a standing wave formed from the incident and reflected wave as the two waves interfere constructively and destructively at different points in space.
1. What is a wire grid polarizer?
A wire grid polarizer is an optical device that is used to selectively filter polarized light. It consists of a series of parallel metal wires placed on a substrate, which allows only light waves with a specific orientation to pass through, while blocking all other polarizations.
2. How does a wire grid polarizer work?
Wire grid polarizers work based on the principle of selective absorption. The metal wires are placed close enough together that they can only allow light waves with a specific orientation to pass through, while other orientations are blocked. This selective absorption results in polarized light output.
3. What are the applications of wire grid polarizers?
Wire grid polarizers have various applications in optics and photonics. They are commonly used in LCD displays, cameras, and other optical instruments to control the polarization of light. They are also used in polarizing filters for photography and in scientific research.
4. Are wire grid polarizers better than other types of polarizers?
It depends on the specific application. Wire grid polarizers have advantages such as high transmission, low reflection, and broad spectral range. However, they may not be suitable for all situations and other types of polarizers, such as polarizing films or crystals, may be more appropriate.
5. Can wire grid polarizers be customized for specific wavelengths or angles?
Yes, wire grid polarizers can be customized for specific wavelengths or angles. The spacing and orientation of the metal wires can be adjusted to achieve the desired polarization properties for a particular wavelength or angle of incidence. This makes them versatile and useful for a wide range of applications.
  • Optics
  • Optics
  • Atomic and Condensed Matter
  • Optics
