Misc. What is the Net Energy Yield for Wood Syngas?
Adam is exploring the cost-effectiveness of using wood gas from cheap wood chips compared to electrical utility rates, specifically off-peak prices of $0.065/kWh. He calculated the cost of wood chips at approximately $0.00216/kWh, factoring in the efficiency of an internal combustion engine, which requires seven times the energy to produce one kWh. The discussion highlights the importance of wood chip moisture content, as it significantly affects energy yield, with dry wood chips providing around 15-20 MJ/kg compared to the estimated 5 MJ/kg for his source. Participants also mention that gasifier efficiencies can reach up to 70%, suggesting that for every kilogram of wood chips, about 0.7 kg of gas fuel could be produced. Understanding these variables is crucial for accurately assessing the net energy yield of wood gasification.
Adam9393
Hello,
My name is Adam and I am experimenting with wood gas. I recently came across a really cheap wood chip source and would like to compare it against electrical utility prices. I am curious if running an old generator would be cheaper than off peak rates of $0.065/kwh.
As of right now, I have calculated that wood chips would cost around $0.0006/MJ (assuming 5 MJ/kg and $3.00/1000kg)
0.0006 x 3.6 MJ= $0.00216 / kwh
Efficiency of internal combustion engine is 0.14. I would need 7x the amount of energy to get 1 kwh.
0.00216 x 7.2 = $0.0155 / kwh.
This is where I am stuck. Does anyone know the net energy yield of wood gasification (softwood chips). If I could factor that into my price will I be pretty close...? Thanks!
Do you know how dry the chips are? That makes a big difference.
https://en.wikipedia.org/wiki/Wood_gas_generator#Design said:
the humidity of the wood (usually 15 to 20%) and the water vapor created by the O- and H-atoms of the dry wood itself (about 0.4 liters of water loaded with organic substances per kg of dry wood) condenses during the gas cooling and filtering procedure and yields a liquid (see also wood tar), which needs specific waste water treatment. This treatment requires about 25 to 35% of the created wood gas energy.
There seems to be a large number of suppliers. https://en.wikipedia.org/wiki/Wood_gas_generator#List_of_commercially_available_systems
If you visit their sites, there might be some efficiency claims.
You should also read the accounts of others who did the same thing.
https://en.wikipedia.org/wiki/Wood_gas_generator#Media_coverage
Likes Klystron and berkeman
I don't understand; are you saying you would use the electricity for electric resistance heat? Why wouldn't you just use the fuel for heat directly like you plan to do with the wood gassification?
Googling "wood gassification energy density" yielded this:
The heat of combustion of "producer gas" — a term used in the United States meaning wood gas produced for use in a combustion engine — is rather low compared to other fuels. Taylor[13]reports that producer gas has a lower heat of combustion of 5.7 MJ/kg versus 55.9 MJ/kg for natural gas and 44.1 MJ/kg for gasoline. The heat of combustion of wood is typically 15-18 MJ/kg.
Is it really $3 per ton? Even if it were free, it's hard to believe you can even haul it to your place of use for that.
Good catch. I missed that. In the south and PNW the prices are $30-$55 per ton.
The price really is $3 per tonne. Yes hard to believe..that is why I am super interested. The chips are not great quality and definitely will not be dry. That is why I assume a conservative energy density of 5 MJ/kg. Dry wood chips are around 15-20 MJ/kg. The distance to transport is not far...max 30 kilometers. I will have to factor this in.
For every unit of heat supplied to the gasification process how much gas energy is yielded. In some documents I have read that gasifier efficiencies are 70%. It has been a while since chemistry class... does this value make sense. If I were to use 1 kg of wood chips to heat up 1 kg of the same wood chips in a gasifier, I would be left with 0.7 kg of gas fuel?
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
Thread 'Nonlinear rubberband type thing - "k" dropping fast as it is stretched'
What materials can I try in order to get a curve of displacement versus force that looks somewhat like this.. (of course, there would be a small kink around the origin where the ends of the rubberband are closer together than its length, which is not shown here). I am looking for something that will last at least 100 stretch cycles and is not messy, so for example liquid based colloidal stuff won't be suitable. Is there something one can whip up using silicone and some additive, say? Or...
