Solving a Word Problem: Preparing Special Eye Drops
  • Thread starter Thread starter Zed
    Eye Word problem
To solve the problem of preparing 16 milliliters of eye drops with a 5% active ingredient using 10% and 1% solutions, two equations are established. The first equation represents the total active ingredient: 0.1x + 0.01y = 0.8, where x is the volume of the 10% solution and y is the volume of the 1% solution. The second equation accounts for the total volume: x + y = 16. By solving these equations simultaneously, the pharmacist can determine the required amounts of each solution. This method ensures the correct formulation of the eye drops for the patient.
Zed
Word problem !
Hi ,
This is a Hw question i have am stuck on i don't know how to solve it ...
A pharmacist is to prepare 16 milliliters of special eye drops for a glaucoma patient. The eye-drop solution must have a 5% active ingredient, but the pharmacist only has 10% solution and 1% solution in stock.
How much of 10% solution should be used to fill the prescription?
How much of 1% solution should be used to fill the prescription?
please help
thx
convert to formulas:
The amount of active solution in each ingredient should sum to the total active solution:
x*.1 + y*.01 = 16*.05
The amount of each ingredition should sum to the total amount:
x + y = 16
Then solve.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
