Is a Constant Force Always Conservative?
A constant force that does not vary with time, position, or velocity is considered conservative. The work done by this force can be expressed using the formula W = FX, which leads to the conclusion that the change in energy is zero when potential energy is accounted for. The discussion highlights a misunderstanding regarding kinetic energy, clarifying that kinetic energy itself is not a non-conservative force. Suggestions include revisiting the definitions of work and conservative forces to clarify the concepts. Understanding these principles is essential for solving the problem correctly.
zoner7
none...
Suppose a force acts on an object. the force does not vary with time, nor with the position or velocity of the object. Start with the general definition of work done by force, and show that the force is conservative
W = FX
Wnonconservative = KE final PE final - KE initial - KE final
I started with W = FX
W = E final - E initial
E = KE f + PE f - KE i - PE i
W = 0 + PE f - O - PE i Since KE is a non-conservation force and there is only a conservative force.
W = PE f - PEi Since PE f = PE i if PE is a conservative force
w = 0
The answer doesn't make any sense... Any suggestions?
Hi zoner7,
zoner7 said:
none...
Suppose a force acts on an object. the force does not vary with time, nor with the position or velocity of the object. Start with the general definition of work done by force, and show that the force is conversation.
W = FX
This line not true. Saying that KE is a non-conservative force is not true.
I would suggest you start with some definitions. What is the general formula for the work done by a force? And also, what is the definition of a conservative force?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
