Work done for isothermal process in terms of Helmholtz func
The Helmholtz function differential form indicates that for a reversible isothermal process, the work done by the system is W = -ΔF, as dT = 0 leads to dF = -PdV. This implies that work is path independent because F is a state variable. However, for irreversible processes, the inequality W ≤ -ΔF suggests that the work done is less than or equal to the change in F, as irreversible processes typically involve additional factors that reduce work efficiency. The confusion arises from interpreting the relationship between work and state variables, as the initial and final states yield the same change in F regardless of the path taken. To clarify, examining specific cases of reversible and irreversible processes under constant external pressure can provide insight into the differences in work done.
Hello890
The Helmholtz function differential form for a reversible process is: dF = -SdT - PdV, as for a reversible process δW (by system/here an (ideal) gas) = PdV and dS = δQ/T.
Therefore, for a reversible isothermal process, dT = 0 and hence dF = -PdV. Therefore, the work done by the system is W = -ΔF. As F is a state variable it is path independent. Therefore, this makes the work done path independent as it is only a function of a state variable?
If this is correct, I do not understand why it is said that for irreversible processes W ≤ - ΔF. Surely, as W is now path independent in this case, W = -ΔF both any process, regardless of wether it is reversible or irreversible. Or is the statement W≤-ΔF simply saying the W for an irreversible process equal to F(initial) - F(final) but will be less that (F(initial) - F(final))for a reversible process?
Science news on Phys.org
From “The Principles of Chemical Equilibrium” by Kenneth Denbigh:
w ≤ – (F2F1) ......... (2-15)
In relation (2-15) the inequality sign refers to an irreversible process and the equality sign to a reversible one. Between the assigned initial and final states the value of F2 F1 is, of course, the same whether the path is reversible one or not, since F is a function of state. Relation (2-15) may thus be interpreted as follows. The work done in a process, in which the initial and final temperatures and the temperature of the heat reservoir are all equal, is either less than or equal to the decrease in F.
From Finn's Thermal Physics book, it gives a similar situation where the adiabatic work W = U(final) - U(initial), and later states that this relation holds whether the process is reversible or not. It says this is true as W is now simply a function of state variables and therefore is path independent. Therefore, I still don't quite understand why W in any isothermal processes not simply W = F(initial) - F(final)? Why is W not simply equal to the decrease in F, now that W is a function of state variables as well?
Why don’t you solve it for two cases (a) reversible and (b) irreversible at constant external pressure (less than the initial pressure) and see how the results compare? In both cases, the system would be in contact with a constant temperature reservoir, equal to the initial system temperature.
Many times, devising and modeling a simple focus problem helps you solidify your understanding.
Likes Lord Jestocost
Thread 'Can somebody explain this: Planck's Law in action'
Plotted is the Irradiance over Wavelength. Please check for logarithmic scaling. As you can see, there are 4 curves. Blue AM 0 as measured yellow Planck for 5777 K green Planck for, 5777 K after free space expansion red Planck for 1.000.000 K To me the idea of a gamma-Ray-source on earth, below the magnetic field, which protects life on earth from solar radiation, in an intensity, which is way way way outer hand, makes no sense to me. If they really get these high temperatures realized in...
  • · Replies 60 ·
9K
  • · Replies 22 ·
  • · Replies 21 ·
