Work done with free body released
The discussion focuses on solving a physics problem involving potential and kinetic energy in a system with two blocks and a spring. The equation used is mgx = (1/2)kx^2 + (1/2)mv^2, where mgx represents the potential energy of block m and (1/2)mv^2 is the kinetic energy of block 2m. A key point is that the velocity v is zero at maximum extension, indicating a change in direction for the mass. Participants suggest drawing a free body diagram to determine the common acceleration and equate the work done to the potential energy stored in the spring. The correct answer of 22 cm is confirmed despite confusion over the application of v in the equation.
jack1234
I have a question here
http://tinyurl.com/2kgeun
My attempts is
mgx=(1/2)*kx^2 + (1/2)mv^2
where mgx is the potential energy of block m
and (1/2)mv^2 is kinetic energy of block 2m.
But this does not seem to work, because we don't have the value v.
May I know how to solve it?
My attempts is
you have the right equation... v is 0 when the object reaches maximum extension... because at this point, the hanging M mass will change from going downward to going upward.
Draw the free body diagram for M and 2M. From that find the common accelaration. Now work done the masses = potential energy stored in the spring. i.e. 3Max = 1/2*kx^2
Thanks, rl.bhat, but I still getting the correct answer(22cm) if sub v=0 in
as mentioned by learningphysics.
