Work/Energy in a Magnetic Field
The discussion centers on the concept of work and energy in a magnetic field, particularly questioning the source of work when magnetic forces cannot perform work. Participants clarify that while magnetic forces influence momentum, they do not contribute to changes in kinetic energy, which is instead due to internal electrostatic forces. The term "magnetic potential energy" is debated, as it can be misleading since the magnetic field itself does not do work. However, it is suggested that attributing the work to internal electric forces allows the term to remain relevant. Overall, the conversation highlights the complexities of understanding energy dynamics in magnetic systems.
MyoPhilosopher
A compass needle has a magnetic moment of 𝜇. At its location, the magnitude of the Earth’s magnetic field is 𝑩 northward at 𝜃 below the horizontal. Identify the orientations of the needle that represent (a) the minimum potential energy and (b) the maximum potential energy of the needle–field system. (c) How much work must be done on the system to move the needle from the minimum to the maximum potential energy orientation?
ΔU = -μBcos(θ)
Sorry if I am asking in the wrong fashion as I am new.
The above questions are easily solvable:
1) U = -μBcos(0)
2) U = -μBcos(180)
3) W = ΔU = 2) - 1)
My question is more related to some theory: where is this work/energy coming from since a magnetic force, to my knowledge can't do "work"?
What force is doing -W (minus W), is it simply the magnetic field, or is there another concrete equation to demonstrate what exactly is happening.
Thank you for anyone that can explain or possibly ask me directional questions
Likes Delta2
It's one of those bizarre situations in physics where a force is responsible for the change in momentum (angular momentum in this case since the needle rotates) but is not responsible for the change in the (rotational) kinetic energy (of the needle). For the latter are responsible internal electrostatic forces that appear inside the needle.
Another example of such a force is the friction between a car's wheels and the road. We all know that a car cannot move without friction, however we all also know that the work isn't done by friction but by the car's engine. So friction is responsible for the change in the momentum of the car, but internal forces at car's engine are responsible for the work done that increases the kinetic energy of the car.
Likes MyoPhilosopher
Thank you for taking the time, great answer!
Likes berkeman
Nice answer!
So it really shouldn't be referred to as "magnetic potential energy" then, right?
The change in the potential energy should be the work done by the magnetic force, but the magnetic force can do no work. I guess it is just a shorthand way of referring to the potential energy associated with a magnetic dipole in a magnetic field. Saying the electric potential energy in this case, would just confuse people.
Rolls With Slipping said:
Nice answer!
Well yes the magnetic field can't do work on matter, hence the term magnetic potential energy becomes problematic at first glance. However we can attribute the work of the internal electric forces as (pseudo) work of the magnetic field force and this can make the magnetic potential energy term viable again.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
