Work/Force question, can anyone explain?
  • Thread starter Thread starter Predator
    Explain
A force of F = (2.80 N)i + (6.80 N)j + (7.05 N)k acts on a 2.00 kg object moving between two positions over 4.00 seconds. To calculate work done, the correct approach involves using the dot product of the force vector and the displacement vector, which is the difference between final and initial position vectors. The magnitude of the displacement should be calculated directly from the vector difference df - di, rather than using individual magnitudes. Average power is determined by dividing the work done by the time interval. Understanding these concepts is essential for solving the problem accurately.
Predator
1. A force F = (2.80 N)i + (6.80 N)j + (7.05 N)k acts on a 2.00 kg mobile object that moves from an initial position of di = (3.05 m)i - (2.00 m)j + (5.00 m)k to a final position of df = -(5.00 m)i + (4.05 m)j + (7.00 m)k in 4.00 s.
W = Fd
I thought I could do the pythagorean theorem for the Force...
square root (2.8^2 + 6.8^2 + 7.05^2), that would give the magnitude of the force.
Then I did the same thing, the magnitude of df - magnitude of di.
Then, (magnitude F) * (magnitude df - magnitude di) = W
But that is incorrect. I am using Web assign online and the answer I get from the previous method does not work. Can anyone explain?
Oh, I forgot the actual question haha.
(a) Find the work done on the object by the force in the 4.00 interval
(b) Find the average power due to the force during that interval.
(c) Find the angle between vectors. di and df.
Here is a definition of work
http://hyperphysics.phy-astr.gsu.edu/hbase/wint.html#wi
One could find it with the magnitude of force applied over the distance.
But then one simply needs to apply the dot or scalar product
F \cdot s, where s is the difference between the position vectors df-di.
Average power is just average work (equivalent to energy) divided by the time over which the work is applied.
does not work in finding the distance.
The distance over which the force is applied is the magnitude of the vector which is found by taking the difference between the position vectors df - di.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
