What is the Work Done by a Pitcher on a Baseball?
  • Thread starter Thread starter goalieguy
    Ball Work
The discussion revolves around calculating the work done by a pitcher when throwing a baseball. The initial calculation of 2.911 Joules was incorrect due to a failure to square the velocity in the kinetic energy formula. The correct formula is (1/2)mv^2, leading to a final answer of 119.351 Joules. Participants emphasized the importance of careful calculations and checking each step. The conversation highlights common mistakes in physics problems and the value of peer assistance in resolving them.
goalieguy
A baseball leaves a pitcher's hand at a speed of 41.0 m/s. The mass of the baseball is 0.142 kg . Ignore air resistance. How much work has the pitcher done on the ball in throwing it?
I've tried using (1/2)mv^2, but there has got to be something weird going on, or i could just be using the wrong equation
thanks for any and all help :smile:
work
i work it out and get the same thing every time i have tried it.
2.911 Joules is the answer I get, and WebAssign says that it is incorrect.
How are you getting that answer? Show what you did.
sorry
Sorry about not showing all the work.
I just take the givens: v=41.0 m/s m=0.142 kg
Then I plug it in to: \frac{m*v^2}{2}
\frac{41*0.142}{2}
That is the answer i come up with (2.911 Joules)
square your 41, boy!
duh. thanks i knew i was doing something completely dumb.
always got to forget the easy part.
right answer = 119.351 Joules
thanks a lot
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
