Work on charge from outside to inside of sphere
The discussion focuses on deriving equations for the electric field and work done in a solid non-conducting sphere with a uniform charge distribution. For the electric field inside the sphere (0<r<R), the equation is E1 = KQR/r^3, while for outside the sphere (r>R), it is E2 = KQ/R^2. Participants point out potential errors in the initial equations, suggesting that variables may have been swapped. The work needed to bring a point charge "q" from infinity to inside the sphere at r = R/2 is derived as W = 11/8 (kQ/R) q, confirming the final answer after addressing integration and dimensional consistency issues. Overall, the discussion emphasizes careful attention to the mathematical details in electrostatics.
origamipro
A solid non-conducting sphere of radius R = 1.12m.
The sphere posses a total charge Qtot spread uniformally throughout its volume.
a) derive equations for electric field for
1) 0<r<R
2) r>R
result in terms of r R and Q
b) Derive an equation that gives the work needed for you to bring a point charge "q" from infinitely far away to inside the sphere at r = R/2
Answer is W = 11/8 (kQ/R) q
for 0<r<R
E1 = KQR/r^3
for r>R
E2 = KQ/R^2
q∫KQR/r^3 + q∫KQ/R^2
1) 0<r<R
2) r>R
for 0<r<R
E1 = KQR/r^3
Something doesn't look right with the above equation for E1. If you show your work we might be able to help figure out what went wrong. (It looks to me as though you have a couple of variables switched around.)
for r>R
E2 = KQ/R^2
Okay, E2 looks like the same problem. Are you accidentally swapping the r and R?
Of course you'll need to make corrections to the terms under the integrals, since they're not quite right. Also, they are path integrals, so you'll need to define the paths. (Start at infinity and go to R, then go from R to R/2).
Also, keep in mind that
W = \int_P \vec F \cdot \vec{dl}
is the work done by the sytem, --the work done by the force -- meaning the work is positive if the force and the direction of the path is in the same direction. On the other hand, the problem statement here asks you to determine the work done on the system, by moving the charge: the work done on the force. Because of that, there is a negative sign involved,
W = -\int_P \vec F \cdot \vec{dl}
After integration
Kq/R + KQ/R^3 (.4704)
KQ/R ( 1 + (1/R^2) (.4704))
KQ/R (11/8) q = answer
origamipro said:
After integration
Sorry, but I don't quite follow what you're doing there.
You're adding one thing that has R in the denominator to another thing that has R3 in the denominator. The terms don't even have the same dimensions. I'm not sure where the .4704 comes from.
That is the correct answer, yes.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
