Work on object lifted in a gravational field
  • Thread starter Thread starter sracks
    Field Work
The discussion revolves around calculating the work done on objects in gravitational fields, specifically focusing on a book being lifted and a particle changing direction and speed.
  • Mixed
  • Participants explore the concept of work done by gravity and the hand when lifting a book, questioning the calculations and assumptions involved. Another participant raises a different scenario involving a particle's change in velocity, expressing uncertainty about their calculations.
Some participants are actively seeking clarification on their calculations and the principles involved, while others are questioning the assumptions made in their approaches. There is a mix of attempts to solve the problems and expressions of doubt regarding the correctness of their methods.
Participants mention specific values and equations but express confusion over the results they are obtaining, indicating potential misunderstandings of the concepts or calculations involved.
sracks
A 1.1 kg book is lying on a 0.80-m-high table. You pick it up and place it on a bookshelf 2.17 m above the floor.
How much work does gravity do on the book?
How much work does your hand do on the book?
W=mgh
(1.1 kg)(9.8 m/s^2)(0.8m)=8.6
The answers that I am getting are wrong
Please help
The book is initially on the table and then its moved to the shelf. So it moved (2.17-0.8) m
Also, work done by gravity will be negative.
Help
Now I have another problem
A 10 g particle is moving to the left at 29 m/s. How much net work must be done on the particle to cause it to move to the right at 47 m/s?
W=mg[tex]\Delta[/tex]r
I got 1.7. I don't think I am doing this right.
Show us how you got 1.7 :confused:
(btw, if you type alt-j, it give you ∆ without having to tex! :smile:)
(.01kg)(9.8m/s^2)(47 m/s - 29m/s) = 1.7
I have a feeling that i am completely doing it wrong
Got it
Forget about this question. I got it
9K
