Calculating Force in Lifting a 2.0kg Object
  • Thread starter Thread starter je55ica7
    Force Lifting
To calculate the work done in lifting a 2.0kg object at a constant speed of 2.0 m/s for 5.0 seconds, the distance covered is determined to be 10 meters. Since the object is lifted at constant speed, the acceleration is zero, indicating that the net force acting on the object is also zero. The force applied by the person must equal the weight of the object, which is calculated using F=ma. Therefore, the work done can be calculated using the formula w=mgh, where h is the height lifted. This confirms that the correct approach to finding the work done is indeed using the gravitational potential energy formula.
je55ica7
How much work is done by a person lifting a 2.0kg object from the bottom of a well at a constant speed of 2.0 m/s for 5.0s?
I know w=fd. I found the distance to be 10m. But what is the force? F=ma so what is the acceleration of the system?
Since the object is being lifted at constant speed, what does that tell you about the acceleration? What's the net force on the object? (There are two forces acting on the object: the force applied by the person and the weight of the object.)
Wouldn't that mean that the acceleration is 0? So would I use w=mgh?
Yes and yes.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
