Checking if IGBT High Side Driver is Working
  • Thread starter Thread starter billy fok
To check if the IGBT high-side driver is functioning, measure the voltage between the positive supply rail and the gate drive using an isolated multimeter. An oscilloscope may be necessary to observe the switching waveforms. The user is utilizing an IRS21850 driver with a 15V supply, a 100μF filter capacitor, and a 10μF charging pump capacitor. It is recommended to add small ceramic capacitors (100nF - 200nF) in parallel to address high-frequency noise from the IGBT. Additional details about the circuit and IGBT part numbers are needed for further assistance.
billy fok
currently I'm using IGBT High Side driver. May i know how to check is the driver working or not working??
Exactly what voltages are you using ? Is it dangerous HV ?
Measure the voltage between the +ve supply rail and the gate drive with an isolated multimeter.
You might need to use an oscilloscope to see the switching waveforms.
Can you post your circuit with component values and the part numbers of the high-side driver and the IGBT.
hi, thanks for the quick reply.. this is the driver that i use (http://www.rcscomponents.kiev.ua/datasheets/irs21850spbf.pdf)
for the filter capacitor value is 100 microF, and the charging pump capacitor 10 microF.
i supply 15V to Vcc... hope you are able to help me.
I assume that your capacitors (10μF, 100μF) are electrolytic capacitors. Remember to add small (ceramic) capacitors in parallel (100nF - 200nF) close to the driver) as the noise from the IGBT includes high frequency harmonics. An electrolytic capacitor is not fit for these, as it has some reactance contained.
Insufficient information. No circuit, no IGBT part number...
Symptoms would also be helpful.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
