Wormholes, Gravity & Interaction: Can a Star Pull a Planet?
In summary, the presence of a gravitating mass close to one mouth of a wormhole may make it impossible for the wormhole to remain open. All known wormhole solutions assume that the wormhole spacetime is asymptotically flat, meaning there are no gravitating masses close enough to affect its geometry. Other masses can affect the geometry, but then it is not considered a wormhole geometry in the literature. It is also believed that gravity waves cannot penetrate a wormhole, and any changes to the mass distribution will not affect the total ADM mass.
Ryan Reed
51
Would objects interact via gravity through the wormhole? Let's say there's a star outside one wormhole, and a planet outside the other, would the star pull the planet through the wormhole?
Putting a gravitating mass close to one mouth of a wormhole might make it impossible for the wormhole to remain open. The wormhole has to have a certain spacetime geometry, and the presence of a gravitating mass, heuristically, would be "trying" to make the spacetime geometry something different. I don't know that there are any known solutions of the Einstein Field Equation that cover this case; all the wormhole metrics that I've seen assume that the wormhole spacetime is asymptotically flat, which translates into English as "there aren't any gravitating masses close enough to the wormhole to affect its spacetime geometry".
The translation into English doesn't seem right. You can have masses that affect the geometry as long as they are not too spread out, and far away the space-time can still be asymptotically flat.
You can have other masses that affect the geometry, but then it isn't a wormhole geometry--at least not a wormhole geometry that appears in the literature. All of the wormhole solutions that have been studied assume that there is no stress-energy present except the "exotic matter" which is needed to hold the wormhole open. I should have clarified that. (Physicists often use the term "asymptotically flat" in the sloppy way I did--not just to mean what it means on its face, but in addition to mean that there is only a certain kind of stress-energy present in the non-asymptotic region.)
I'm fairly sure that "gravity" won't penetrate a wormhole. This is based mostly on some popular articles by Cramer in the science fact section of Analog on wormholes that one can find online, plus some recollections from Visser's book, "Lorentzian Wormholes", which I did read at one time but don't have handy to refer to to give an exact quote. Visser's book isn't terribly techical, if the OP can find it it might be good to order it from a library (interlibrary loan).
Anyway, the basic idea to sketch a proof would be to consider two separate asymptotically flat space-times, connected via a wormhole. Then at spatial infinity of each of in each asymptotically flat space-times, there is an ADM mass, which basically can't change as it's defined at spatial infinity. So if you move one end of the worhole around in it's own separate asymptotically flat space-time, there just isn't a way for the changes to propagate through to the other end, the continuity conditions prevent the ADM mass of the other end form changing.
It's also interesting to consider what happens when a mass passes through the wormhole, but this isn't strictly relevant to the OP's question.
[add]Perhaps it could be somewhat relevant, one can consider what hapens if a gravity wave, emitted by the changing configuration in one asymptotically flat space-time, propagates throught the wormhole. Basically the total ADM mass of the wave + exit wormhole mouth doesn't change, but the distribution changes, so the exit end gets "lighter" and the gravity wave propagates normally.
Usually this effect will be negligible - gravity waves just don't carry that much energy under normal circumstances.
1. How are wormholes formed?
Wormholes are theoretical structures that are formed by the bending of spacetime. According to Einstein's theory of general relativity, massive objects can create a curvature in spacetime. If this curvature becomes extreme, it can create a tunnel-like structure that connects two distant points in spacetime.
2. Can wormholes be used for time travel?
The concept of using wormholes for time travel is still a topic of debate among scientists. While some theories suggest that it may be possible, it is currently not supported by any scientific evidence. Additionally, even if it were possible, the immense amount of energy required to manipulate wormholes would make it practically impossible.
3. How does gravity play a role in the interaction between a star and a planet?
Gravity is the force of attraction between two objects with mass. In the case of a star and a planet, the star's massive size creates a strong gravitational force that pulls the planet towards it. This force is what keeps the planet in orbit around the star.
4. Can a star pull a planet into a wormhole?
No, a star cannot pull a planet into a wormhole. While a star's gravitational force is strong, it is not strong enough to create a wormhole or manipulate one. Wormholes are formed by the extreme curvature of spacetime, which is not affected by the gravitational pull of a single object.
5. Is it possible for a planet to escape the gravitational pull of a star?
Yes, it is possible for a planet to escape the gravitational pull of a star. This can happen in two ways - either the planet gains enough speed to break free from the star's gravitational pull, or the star loses its mass and becomes less massive, resulting in a weaker gravitational force. However, in most cases, a planet will remain in orbit around its star due to the balance between the gravitational force and the planet's own velocity.
  • Astronomy and Astrophysics
