I Would moving the mouths of a wormhole affect the internal distance?
  • I
  • Thread starter Thread starter Earthworm69
    distance Wormhole
Earthworm69
TL;DR Summary
If you move one mouth of a wormhole away relative to the other mouth, what happens to the space inside of it?
Lets say I formed a traversible wormhole with one mouth on each end of my garage. If I picked up one of the ends and drove it to the park, would the distance inside the wormhole increase or otherwise be effected as well?
This is my first post on physics forums - Hi everybody!
https://en.wikipedia.org/wiki/Wormhole
In the traversable wormhole solution described in the Wikipedia article you reference, the one published by Kip Thorne and others, no, the distance through the wormhole would not change.
Welcome!
Are there any solutions where the inside distance can change if the mouths are moved?
Not that I'm aware of, but I am not up to date on all of the wormhole literature.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
