Would the velocity of a fluid increase right after exiting a pipe into open air?
The discussion revolves around the behavior of a fluid as it exits a pipe into open air, specifically focusing on the changes in static and dynamic pressure, velocity, and the implications of these changes in both inviscid and viscous flow scenarios. Participants explore theoretical aspects, potential models, and the implications of fluid dynamics principles.
  • Some participants propose that if a non-viscous incompressible fluid exits a pipe with a static pressure higher than atmospheric, the dynamic pressure should increase, implying an increase in velocity outside the pipe.
  • Others argue that the static pressure at the pipe's exit is atmospheric, questioning the assumption of a discontinuity in pressure.
  • A few participants suggest that the mass flow rate and fluid velocity should remain constant within the pipe, raising questions about energy conservation as pressure decreases to atmospheric levels.
  • Some participants inquire whether a velocity distribution could exist where parts of the fluid move at different speeds while maintaining overall mass flow, particularly in an inviscid scenario.
  • There is a contention about whether it is possible for an inviscid fluid to have a static pressure greater than atmospheric within the pipe, with some asserting it is impossible without a decreasing pipe diameter.
  • Participants discuss the effects of viscous flow, including the potential for air entrainment to affect static pressure just beyond the pipe exit, although some note this effect is typically insignificant in analysis.
  • One participant describes a specific case involving a ducted fan, suggesting that pressure dynamics can be complex and vary along the length of the tube.
Participants express multiple competing views regarding the behavior of fluid pressure and velocity as it exits the pipe. There is no consensus on the implications of static and dynamic pressure changes, and the discussion remains unresolved on several key points.
Limitations include assumptions about fluid viscosity, the effects of friction, and the conditions under which pressure dynamics are analyzed. The discussion does not resolve the complexities of these factors.
dddoi
If you have an non-viscous incompressible fluid flowing in a pipe whose static pressure is higher than atmospheric pressure, then after exits the pipe will the dynamic pressure increase? The static pressure of the fluid right after exiting should decrease because it should be equal to the atmospheric pressure, so since the total pressure should stay the same the dynamic pressure would increase.
The increase in dynamic pressure implies an increase in the velocity the fluid, which seems to spell trouble because that would mean the flow rate inside the pipe is lower than the flow rate outside the pipe.
Any help would be greatly appreciated!
The static fluid pressure inside the pipe near its exit is atmospheric. What made you think that the static pressure is discontinous? Fluid pressure is a continuous function of spatial position.
My bad, my poor wording may have suggested that but I didn't think that. Regardless, doesn't the dynamic pressure near the exit still increase? A few centimeters from the end of the pipe, the static pressure is the atmospheric pressure so the dynamic pressure is higher, right? But in order for the volume flow rate to be the same there and somewhere inside the pipe, the cross-sectional area must be lower. The cross-sectional area doesn't seem to decrease, rather it increases which means my reasoning went awry somewhere but I can't see where.
Assuming no losses in the system, such as friction within the pipe, and no changes in temperature, density, ... , and a pipe with constant cross sectional area, then mass flow and fluid velocity should be constant within the pipe. If the pressure decreases from above ambient to ambient near the end of the pipe, what accounts for the decrease in total energy as the fluid approaches the end of the pipe (where is that energy going)?
Can the mass flow be distributed over the cross sectional area so that some parts of the fluid move slower while other parts move faster, in such a manner that the overall mass flow remains constant, but the velocity distribution results in an increase in dynamic pressure while the static pressure decreases? For a fluid with no viscosity, I'm wondering if such a velocity distribution could be determined.
For an inviscid fluid, the pressure in the pipe is not decreasing along the pipe.
For an inviscid fluid, the velocity profile in the pipe is flat.
What about the velocity just outside the pipe? Is the higher because of the decrease in static pressure? Or is it the same?
As I said, the static pressure does not decrease. I don't know how may different ways there are to say this.
I'm confused, assuming the static pressure within most of the pipe is greater than atmospheric, then where does the static pressure decrease to atmospheric, or is it impossible for an inviscid fluid to have a static pressure within the pipe greater than atmospheric ?
It's an impossible assumption because with invincible flow there can be no friction in a pipe, so no way for there to be a pressure gradient. But either way (even with viscous flow/drag), the pressure at the outlet is atmospheric.
Yes. It's impossible unless the pipe diameter is decreasing before the exit.
With a viscous flow (at least on the part of the air outside the pipe), it would seem that the entrainment of the air just beyond the end of the pipe could cause the affected air's static pressure to go above atmospheric and return to ambient somewhere beyond the end of the pipe.
This effect would be very insignificant; I have never seen it included in the analysis of exit effects for viscous flow. For viscous flow, the main exit effect is the transition from the parabolic velocity profile inside the pipe to a flat velocity profile beyond the tube exit. This gives rise to an additional pressure drop, equivalent to an additional tube length on the order of about one tube diameter. Fluid inertia interacts with this and leads to the so-called vena contracta effect.
Consider the case of a ducted fan with no taper in the tube (some model aircraft ducted fans are setup this way). My understanding is that the pressure in the tube ahead of the fan is lower than atmospheric and the pressure in the tube behind the fan is greater than atmospheric. The pressure in the tube would decrease due to friction, but unless the tube was fairly long, the pressure would remain above atmospheric until very near the end of the tube where the flow could get complicated (turbulent) due to interaction with the free stream air.
That's not what would happen. After the fan, the static pressure would decrease linearly from the value exiting the fan to atmospheric pressure at the tube exit.
  • · Replies 48 ·
  • · Replies 35 ·
  • · Replies 20 ·
  • · Replies 18 ·
  • · Replies 19 ·
  • · Replies 73 ·
17K
  • · Replies 48 ·
