How Do You Write the Function for a Traveling Wave on a String?
A wave travels along a string at 27 m/s with a frequency of 46 Hz, and the function for the wave is expressed as y(x, t) = Asin(κx - ωt + ∂). The values for angular frequency (ω) and wave number (κ) were calculated as 289.03 and 10.70, respectively. The challenge lies in determining the amplitude (A) and phase (∂) based on the initial conditions provided, specifically that y(0,0) = 0.003 m and the vertical velocity at that point is 2.6 m/s. The final solution for the wave function is confirmed as 0.0095 sin(10.70x - 289.03t + 2.82), with the phase adjustment made to ensure it falls within the correct quadrant.
Renaldo
A wave travels along a string in the positive x-direction at 27 m/s. The frequency of the wave is 46 Hz. At x = 0 and t = 0, the wave velocity is 2.6 m/s and the vertical displacement is y = 3 mm. Write the function y(x, t) for the wave. (Use the following as necessary: x and t. Assume x and y are in m, and that t is in s.)
y(x,t) = Asin(κx - ωt + ∂)
ω = 2pif = 2pi(46) = 289.03
κ = ω/v = 289.03/27 = 10.70
I determined that:
y(x,t) = Asin(10.70x - 289.03t + ∂)
y(0,0) = Asin(∂) = 0.003 m
Here is where I have trouble. I tried to take a partial derivative of the first function in order to solve for the velocity, since velocity is given. I've never encountered partial derivatives before, so I am not sure if what I did is correct. It doesn't give me the right answer.
yt= -289.03Acos(10.70x - 289.03t + ∂)
If (x,t) = (0,0)
yt = -289Acos(∂) = 2.6 m/s
I tried to combine this equation with
Asin(∂) = 0.003 m
to solve for ∂ and A, but I wasn't close to the final answer.
Is this a matter of taking the partial derivative wrong, or am I making some other mistake?
... the wave velocity is the speed of the wave in the x direction.
the partial derivative: ∂y(x,t)/∂t is the speed of point x in the y direction.
If the wave at t=0 has form ##y(x,0)=f(x)## and it is traveling in the +x direction with speed c,
then at time t it will have form: ##y(x,t)=f(x-ct)##.
In your case, f(x) is the wave equation at t=0.
Simon Bridge said:
If the wave at t=0 has form ##y(x,0)=f(x)## and it is traveling in the +x direction with speed c, then at time t it will have form: ##y(x,t)=f(x-ct)##.
Thanks for the response.
At t = 0, x = 0.
y(0,0) = Asin(∂)
According to the problem, at this point, y(0,0) = 0.003 m.
So:
Asin(∂) = 0.003 m.
I now have two variables, A and ∂. How do I solve for them?
If (x,t) = (0,0)
Asin(∂) = 0.003 m
You did it right. Show your further work.
ehild
Looking at it again and squinting this time:
...this could be interpreted either way ... this wave velocity could be the rate of change of displacement y of whatever is at point x or it could be the speed of the whole wave-form (and if the latter, why mention the x position?) ... but it has already been said that:
... OK, so c=27m/s and vy(0,0) = 2.6m/s
So what was the final answer supposed to be?
What did you get?
Equation #1: -289Acos(∂) = 2.6 m/s
Equation #2: Asin(∂) = 0.003 m
Equation #1 (solved for A): A = 2.6/[-289.03cos(∂)]
Equation #2 (with substitution): (-2.6/289.03)tan(∂) = 0.003
(cont.) tan(∂) = -(0.003*289.03)/2.6
∂ = tan-1[-(0.003*289.03)/2.6]
∂ = -0.32
Back to Equation #2: Asin(-0.32) = 0.003
A = -0.0095 (Amplitude is always positive, so can I just disregard the negative sign?)
The correct answer is: 0.0095 sin (10.70x - 289.03t + 2.82)
My answer as it is currently: 0.0095 sin (10.70x - 289.03t - 0.32)
My phase does not equal 2.82. Yet, using -0.32 as the phase resulted in the correct amplitude (assuming that it is alright to disregard the negative sign.)
∂ = -0.32
You got A correctly. The easier way to calculate it is:
Acos(δ)=-2,6/289=-0.009
Asin(δ)=0.003
Square both equations and add them together: A2cos2δ+A2sin2δ=A2=90*10-6, A=0.0095.
From the first equations you see that sin(δ) >0 and cos(δ)<0. So δ is in which quadrant?
ehild
I see now. It is in the second quadrant. I need to add pi to -0.32 which results in 2.82.
Thanks! I think I can go to bed now...
Good night! :)
ehild
