Is There a Shortcut for Writing Limits in Math?
In summary, writing limits can be tedious, especially on exams, as you are expected to write "lim x->a" on every line unless it is not a limit. While developing a personal notation can help with private notes, it is important to include the "lim x->a" part in preliminary steps of evaluating a limit. There may be shortcuts for some algebraic manipulations, but ultimately, writing out the limit multiple times is necessary. Overall, it is important to be meticulous and accurate in writing limits, as they are a crucial concept in mathematics.
ZeroPivot
55
so solving lim's can be tedious not because they are hard but because you have to continously keep writing lim x->a while solving the equation is there a mathematical shortcut to writing limits without keep writing lim x->a all the time after each development?
thanks.
Mathematics news on Phys.org
You can develop your own private notation for your private notes ... for example just draw an underline, and make a note as to what it means.
Likes 1 person
i know, but i meant for the exam will => do the trick?
On an exam you are likely to be expected to write [itex]\displaystyle \lim_{x\to a} [/itex] on every single line, unless you are actually writing something down which is not a limit. Your instructor's opinion may vary (you should ask them if you feel it's really important), but I find it unlikely. There are two reasons for this
1.) Writing six characters four or five times doesn't take that much time.
2.) A LOT of students don't understand what limit notation actually means, so instructors absolutely need to grade on correctness here.
3.) You should never write down things which are not mathematically true on an exam, and this is no exception.
Likes 1 person
A significant amount of the work in evaluating a limit is manipulating the expression so that you can actually take the limit. For these preliminary steps, since you haven't taken the limit yet, it's important that you include the "lim x -> a" part.
Likes 1 person
Quite frankly, if the hard part is writing the "[itex]\lim_{x\to a}[/itex]" you must be brilliant- and painfully lazy!
If your algebra goes [itex]\lim_{x\to a}f(x)=\lim_{x\to a}g(x)=\lim_{x\to a}h(x)=\lim_{x\to a}k(x)=L[/itex], and if the above equality holds because [itex]f=g=h=k[/itex] everywhere, then you could do your algebra in two steps:
- [itex]\forall x, \enspace f(x)=g(x)=h(x)=k(x)[/itex].
- Therefore [itex]\lim_{x\to a}f(x)=\lim_{x\to a}k(x)=M[/itex].
Likes 1 person
some of the lims get a bit complicated and keep writing lim x->a all the time like 10 times is a pain in the butt.
Then you can do it like economicsnerd suggests below.
Yep, that's "painfully lazy"!
I, on the other hand, am painfully lazy but NOT brilliant.
1. What is a limit in math?
A limit in math is a fundamental concept that describes the behavior of a function as its input (usually denoted by x) approaches a certain value (usually denoted by c). It is used to determine the value that a function will approach as its input gets closer and closer to the specified value.
2. How are limits typically written in math?
Limits are typically written in the form limx→c f(x) = L, where c is the value that x is approaching and L is the limit or value that the function f(x) will approach as x gets closer and closer to c.
3. Can limits be evaluated algebraically?
Yes, limits can be evaluated algebraically using certain properties and rules of limits. These include the limit laws, which allow us to manipulate limits algebraically, and the squeeze theorem, which can help us find the limit of a function that is difficult to evaluate directly.
4. Are there any shortcuts for writing limits in math?
Yes, there are some shortcuts for writing limits in math. For example, if a function f(x) has a removable discontinuity at the point c, we can use the simplified notation limx→c f(x) instead of limx→c f(x) = L to indicate that the limit exists but is not equal to L.
5. How can I determine if a limit exists?
A limit exists if the left-hand and right-hand limits are equal at the specified value c. In other words, if limx→c- f(x) = limx→c+ f(x), then the limit limx→c f(x) exists. Additionally, if the function is continuous at c, then the limit exists and is equal to the value of the function at c.
  • General Math
  • General Math
  • General Math
