Building a WWII Airplane: Materials, Propellers & More
  • Thread starter Thread starter ABHIdAVIATOR
    Airplane Time
Building a WWII airplane requires careful selection of materials, with aluminum being a common choice for structures like the P51, while some aircraft, like the Mosquito, utilized wood and fabric. For wing coverings, lightweight cloth or plastic sheets are recommended. The construction involves using wood for spars and steel or aluminum pipes for the frame. Additionally, determining the appropriate propeller RPM is crucial for performance; resources are available online for specific models. Overall, the project demands a blend of traditional and modern materials to achieve authenticity and functionality.
ABHIdAVIATOR
I'm planning to build myself a WWII time Airplane. i need some insght into the types of materials that can be used for it.
Specifically, I'm facing problem in finding a suitable covering material for the wings. i would require a light cloth or a plastic sheet, probably. I've used wood to make the spars. I'm using steel and aluminium pipes to construct the frame.
Also, i need to know the rough value of rpm of the propeller that i should have.
please help me out with this.
Suggestions welcomed. Thank u in anticipation.
Abhishek
INDIA
The Mosquito was a wood and fabric airplane. That's an exception though. Most were metal or mixtures of.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
