What are alternative methods for solving the O.D.E. y'=(x^2+y^2)/xy?
  • Thread starter Thread starter asdf1
    Ode
The discussion focuses on solving the ordinary differential equation (O.D.E.) y' = (x^2 + y^2) / xy, which is not separable. A change of variables, specifically y = xV(x), is suggested to transform the equation into a separable form. The substitution leads to the simplified equation z' = 1/(xz), which is separable and can be solved. The solutions derived indicate that both positive and negative signs are valid, as both y and -y satisfy the original O.D.E. However, specific initial or boundary conditions would yield a unique solution.
asdf1
for this O.D.E. :
y`= (x^2 + y^2)/xy
it's unseparable, so what other methods can there be taken?
It's a change of variables case (actually excercise #1 in my book on this topic), the way you do this is check to see whether f(x,y) = f(tx,ty), where f(x,y) = dy/dx.
So if you substitute tx and ty for x and y respectively, you'll see that equality holds. Then do following substitution: y = x V(x) into the DE and see what you get with applying dy/dx and some simplifications. It should reduce to separable equation.
This is just like the post about the other ODE. You can write it as:
y'=x/y+y/x
Again, with the substitution z=y/x it becomes:
z+xz'=1/z+z
or
z'=1/(xz)
which is separable.
it's homogenous, separable, use v=y/x
ok, thanks!
here's my work:
y`=x/y +x/y
suppose y=vx
=>v=y/x
=> y`=v+xv`
so v+xv`=1/v+v
=> vdv=dx/x
=> v^2=ln[absolute value(x)]+c`
=> (y^2)/(x^2)=ln[absolute value(x)]+c
=> y^2=2(x^2)ln[absolute value(x)]+cx^2
now if i take the square root on both sides, there should be a positive and negative sign on the right~
the correct answer should only have the positive sign, but how can you be sure that it should be positive?
asdf1 said:
here's my work:
y`=x/y +x/y
suppose y=vx
=>v=y/x
=> y`=v+xv`
so v+xv`=1/v+v
=> vdv=dx/x
Whoopsie, you've forgot a factor 1/2 on the left side.
You can use either sign, both will be valid solutions to the ODE. This becomes clear when you plug y back into the ODE to check if it works out. Then, with the benefit of hindsight, you could foresee this, since if y is one solution, then the other is -y and it's derivative is -y'. If you write the ODE as xyy'=x^2+y^2 you can see that if y is a solution, then -y is too.
Ofcourse, if you're given a boundary value or initial value/condition then there will be only one solution. (otherwise the problem is ill-stated).
thank you very much! :)
