Yet another epsilon-delta proof
  • Thread starter Thread starter bjgawp
    Proof
The discussion revolves around proving the limit of the function as x approaches negative infinity, specifically that lim_{x \to -\infty} (2/√(x^4 + 1)) = 0. Participants express confusion regarding the logical steps in the epsilon-delta proof, particularly about the relationship between negative and positive values in the context of the limit. Clarifications are made about the absolute value and inequalities, emphasizing that for x < 0, the absolute value of 1/x is indeed -1/x, which is positive. The conversation also touches on the need for better resources on epsilon-delta proofs, with suggestions for further learning. Overall, the thread highlights the complexities and common misunderstandings surrounding limit proofs in calculus.
bjgawp
Prove that \lim_{x \to -\infty} \frac{2}{\sqrt{x^{4}+1}}=0\
Preliminary Work
http://img339.imageshack.us/img339/401/proofzr7.jpg
Before proceeding on with the proof, when we look at the last line there seems to be a logical problem. We know that \epsilon > 0 and x < N < 0 . Thus, it seems counter-intuitive that x is greater than a positive expression but less than a negative. Just a guess but I think it has something to deal with the second last line involving the square root. Thanks in advance!
Edit: Are there any texts that you guys suggest for learning epsilon-delta proofs? The examples that we do in class seem to be repetitive but when it becomes more abstract and general, some ingenuinity is needed and I would like to see some of these proofs worked out. Thanks!
Should move this to calculus for better results and don't expect much. Delta-epsilon proof is a confusing topic
It sure is counterintuitive. How can you say that the solution set to |x|>C is C<x<-C? Don't you mean x<-C or x>C?? E.g. imagine C=2.
How do i get from the penultimate line to a solution for x? If I proceed:
x < \sqrt[4]{\frac{2}{\epsilon^{2}}-1} and set N to that when we give the formal proof, this would contradict one of our initial statements that N < 0 since the expression \sqrt[4]{\frac{2}{\epsilon^{2}}-1} must be positive. So I'm not sure what the solution set of x would be.
Can you use what you know about x<0? So from your next to last line, say
|x| &gt;\sqrt[4]{\frac{2}{\epsilon}-1}
-|x|&lt;\sqrt[4]{\frac{2}{\epsilon}-1}&lt; |x|, but you know that x=-|x|
Okay, I obviously need to work on my tex communication skills, but hopefully you can make sense of this.
Call C your fourth root expression. Yes, C is positive. You want |x|>C and x negative. You want x<-C. I don't see your 'contradictions'.
Ah it's all clicked in guys. So for the formal proof I'll set N = -C.
Edit: Sorry if I need to post another thread but just a quick question about a simpler proof.
Prove that \lim_{x \to -\infty} \frac{1}{x}=0
In the solutions manual:
For x < 0, |\frac {1}{x}-0|=- \frac{1}{x}. If \epsilon > 0 is given, then - \frac {1}{x}&lt; \epsilon which means x < - \frac{1}{\epsilon}.
Take N = - \frac{1}{\epsilon}. Then,
x &lt; N
x &lt; -\frac{1}{\epsilon}
|-\frac{1}{x} - 0| = -\frac{1}{x} &lt; \epsilon
So, \lim_{x \to -\infty} \frac{1}{x}=0
My problem is with the initial statement claiming that |\frac {1}{x}-0|=- \frac{1}{x}. I fail to see how this works as the absolute value of a function yields positive values, does it not? And wouldn't the proof work if we just made the condition that \frac{1}{x} &lt; 0 &lt; \epsilon , implying that x &lt; 0 &lt; \frac{1}{\epsilon}?
I apologize in advance if my train of thought isn't presented very clearly. Thanks again!
Again, your limit is as x approaches neg inf, so x is negative. So the absolute value |1/x -0| = -1/x is positive.
Also, since x<0, when you multiply both sides of 1/x < eps by x, the inequality flips. Does that make sense? You know that eps is positive and x is negative, so you can't say that 1/eps < x. Sorry for my lack of tex. I'm working on that.
Ah It all fell into place. Thanks a lot klile82 and Dick!
I'll definitely be back with more ... XD
Following Dick's advice and posting a new thread.
The statement you want to prove doesn't make much sense. Could you post it exactly as stated? And I would suggest you start another thread with a new problem. You'll get a lot more attention that way. If I see an active thread with over 5 posts, I don't generally don't even check it. Figure the issue is in the process of being beaten to death. Or that the poster is so confused no one can help.
Sure no problem. And i wrote the question wrong, sorry!
