CompSci
- 9
Drive two 15m long optical fibers extended in opposite directions with a 1GHz pulse generator. The recievers at the end of each fiber are now syncronised sources of 1GHz pulses. Connect them to pulse counters, one of which provides a signal whenever a pulse train is present.
Connect this "clock on" signal to a laser aimed at the second station. When the pulse train appears, this laser will turn on. The beam is directed at a beam splitter. Adjust the beam splitter so that the intensity of the light beams hitting a detector located 1cm from the the splitter and a detector located 30.01m away at the second station are approximately equal.
These detectors are connected to the corresponding pulse counter's "count disable" input. When the pulse generator is turned on, both counters count pulses. When the laser turns on, the counter next to the laser stops counting almost immediatly. The second counter should stop counting when the laser signal has traversed the 30.01m separation. Build a 10ns delay into the firing circuit of the laser so that the counter close to the laser will show 10 counts. My expectation is that the distant counter will show 110 counts.
Since 100 pulses indicate a transit time of 100ns for a 1GHz clock, the measured velocity of c will be: 30m / 100*10^-9s, giving a value of c=3.0*10^8ms.
Is this a valid determination of the one-way speed of light?
