Wind Chill Factor: Real or Perceived?
  • Thread starter maximus
In summary: If you cover that sensor with something then the car won't be able to get an accurate reading of the outside temperature.
maximus
495
this one is simple: is the wind chill factor an actual factor or is it only perceived by humans?
Biology news on Phys.org
What do you mean by a "real factor"?
It's the same factor that happens when you blow on soup, the air movement increases the loss of heat, hence, it cools faster.
For an inanimate object, windchill has an effect if the object is warm. For example, say that you fill two glasses with the same amount of 100-degree water. You put one glass in your refrigerator, which is at 35 degrees, and one outside, where it is 35 degrees and the wind is blowing at 25 mph (so the windchill makes it feel like 8 degrees). The glass outside will get cold quicker than the glass in the refrigerator because of the wind. However, the glass outside will not get colder than 35 degrees -- the air is 35 degrees whether it is moving or not. That is why the thermometer reads 35 degrees even though it feels like 8 degrees.
It is perceived not only humans. Try to chill your processor without wind (fan) - what happens then?
Water cooling is very efficient.
Yes. For human too.
Oh yeah... try it... :wink:
look, i was just wondering how my car can give an accurate reading of the outside temperature while in motion
The thermometer is probably in a compartment or part of the car that doesn't feel much wind. You could mostly enclose it, but leave enough ventilation opening to the rear so that the air inside the compartment would stay the same temp as the outside but not feel much wind.
Hey, who's topic is this anyways!
The engine sensory on many cars is on the right side of the engine, top right corner of radiator.
What is wind chill factor?
Wind chill factor is a measure of how cold it feels outside when wind is factored in with the actual air temperature. It takes into account the rate at which heat is lost from the human body when exposed to wind and cold temperatures.
Is wind chill factor a real or perceived phenomenon?
Wind chill factor is a perceived phenomenon, as it is a measure of how cold it feels to humans, rather than an actual physical measurement. However, it is based on scientific principles and can help us understand and prepare for the effects of cold weather.
How is wind chill factor calculated?
Wind chill factor is calculated using a formula that takes into account air temperature and wind speed. The formula was developed by the National Weather Service and is based on the rate at which heat is lost from exposed skin when exposed to wind and cold temperatures.
Does wind chill factor affect non-living objects?
No, wind chill factor only affects living beings with skin that is exposed to the elements. Non-living objects, such as buildings or vehicles, do not experience wind chill factor.
How does wind chill factor impact the human body?
Wind chill factor can make it feel colder than the actual air temperature, which can increase the risk of hypothermia and frostbite. It can also cause discomfort and make it more difficult for the body to maintain a steady internal temperature.
  • Earth Sciences
  • Electrical Engineering
  • Biology and Medical
  • Mechanical Engineering
