How Do You Calculate the Linear Speed of a Yo-Yo Using Energy Conservation?
The discussion focuses on calculating the linear speed of a yo-yo using energy conservation principles. Participants clarify that the correct approach involves equating gravitational potential energy lost to the kinetic energy gained, considering both linear and rotational motion. The moment of inertia provided is crucial, and the radius used for calculations should be the inner radius where the string unwinds. After resolving various misunderstandings about the equations and the radius, the correct final speed is determined to be approximately 0.3058 m/s. The conversation emphasizes the importance of correctly applying the principles of energy conservation and understanding the geometry of the yo-yo.
postfan
A yo-yo has mass 0.8 kg and rotational inertia 0.12 kg m2 measured about an axis perpendicular to the screen and passing through its center of mass. A light thin string is wrapped around the central part of the yo-yo that has radius 0.03 m. The string is attached to the ceiling as shown. The yo-yo is released from rest and begins to descend as the string unwraps.
Use conservation of energy to find the linear speed of the yo-yo by the time it descended a distance 0.8 m. Use g = 9.8 m/s2.
Used conservation of energy :mgh=.5mv^2+.5Iw. w=v^2/r^2. v=3.74.
What am I doing wrong?
Is the question to find the vertical velocity? At what distance fallen? You really should quote the entire question exactly as it is given to you. If you have, the answer cannot be found.
Which radius did you use in w=v/r ?
This is quite a common HS problem, it is reasonable to put I as about the center of rotation here:
You need to explain your reasoning here and show the rest of your working for this to make any sense.
The attached diagram does not belong to this problem either - it's missing at least one force.
Then - there is no question in the problem statement.
The basic approach - that grav PE lost is stored as linear motion and in the rotation of the yoyo - is correct.
Well m=.8, g=9.8, h=.8 w=v/r. So I substituted these values in the above equation and got 3.74, which I know is wrong. So what am I doing wrong?
I resolved it and got the same answer 3.74, but it is wrong, can anyone please tell me why that's so?
Double check your arithmetic.
Is the answer 3.69?
What is the radius of the entire yo-yo?
The whole thing has rotational K.
The radius is .03.
That is the inner radius where the string is tied according to the diagram.
Can we say that the radius of the entire yo-yo is R?
You are given the rotational inertia. Since the problem does not state what type of extended mass the yo yo is we need the radius. Are you looking at the correct diagram?
The diagram is correct, and the problem doesn't give us the radius of the entire yo-yo.
The problem states the rotational inertia of the entire yo-yo so use that. From the first post in thread:
postfan said:
A yo-yo has mass 0.8 kg and rotational inertia 0.12 kg m^2
Why would you need that?
Wait , do I need to find the radius or not?
I wast thinking v^2 / r^2 part?
But now I think I can find omega...
I'm really confused , do I need to find the radius or not?
The problem states that the yo-yo has rotational inertia I = 0.12 kg m^2. There's no need to find the radius of the yo-yo, and that wouldn't help unless you knew how the mass in the yo-yo was distributed.
There's also a typo in your equation (you left out the ^2 for w^2), which should be:
m g h = .5 m v^2 + .5 I w^2
So do I just substitute and solve?
Yes. It seems you've already figured out how to relate w to v.
Is the answer 3.741657?
Yes, check the calc. I'm getting less than 1 for the velocity after falling 0.8 m.
You could show the details of your calculation if it still doesn't work out so we can compare with you.
Here's my calculation
mgh =.5mv^2+.5Iw^2
2gh = v^2 + .12*v^2
.62v^2=2*9.8*.8
v^2 = 2*9.8*.8/.62
v=sqrt(2*9.8*.8/.62)
mgh =.5mv^2+.5Iw^2
2gh = v^2 + .12*v^2
In this step you lost the I and forgot to divide the second term on the right by m. Also, you replaced w with v, when it should be w = v/r.
In the next step, I don't see how you got .62v².
Not a bad idea to hold the numbers until you have it solved for v.
After multiplying your first step by 2 and replacing w with v/r you have
mgh = v²(m + I/r²)
Dividing both sides by the brackets solves for v².
Ok, so is the answer 2.64575?
v^2=(mgh)/(m + I/r²)
V^2=(mgh)/(m+.12mr^2/r^2)
v^2=(mgh)/(1.12m)
v^2=(gh)/1.12
v=sqrt((gh)/1.12)= 2.64575
you left out the .5's
v²=(mgh)/(.5 m + .5 (I/r²))
v²=(mgh)/(m+.12mr²/r²)
You multiplied the inertia term by r^2, the equation should still be:
v² =(mgh)/(.5 m + .5 (I/r²))
Ok so
v^2=mgh/(.5m+.5(I/r^2)
v^2=mgh/(.5m+.06(m*r^2/r^2)
v^2=mgh/(.5m+.06m)
v^2=gh/(.56)
v=sqrt(gh/.56)=3.74165
Doesn't the moment of inertia equal mr^2, and is this right?
postfan said:
Doesn't the moment of inertia equal mr^2?
The moment of inertia of the yo-yo I = .12 kg m^2 (where m is meters, not mass). The radius of the yo-yo is already taken into account for this stated moment of inertia and is not related to the radius of the central part that the string unwinds from. So just continue from here:
v^2=((.8)(9.8)(.8))/((.4)(.5*.12))
v=((.8)(9.8)(.8))/((.4)(.5*.12))^.5=16.1658.
How's that?
  • #31
Yes, the moment of inertia will NOT be mr² because it is not a simple ring.
  • #32
What happened to the plus sign, lost between these two lines? Also I don't see dividing by .03 squared.
  • #33
Ok so v=((.8)(9.8)(.8))/((.4)+(.5*.12/.03^2))^.5 = .3058. Is that right?
  • #34
Yes, that seems correct.
  • #35
Yep, I agree!
  • #36
Ok, thanks for all your help!
  • #37
Good to see someone else was helping while I was away :)
Just checking...
energy lost falling distance h is ##mgh = (0.8\text{kg})(9.8\text{N/kg})(0.8\text{m}) = 6.2720\text{J}##
... notice that working and the answer includes the units?
this energy goes into kinetic energy by $$mgh=\left ( \frac{m}{2}+\frac{I}{2r^2}\right )v^2 = \frac{mr^2+I}{2r^2}v^2\Rightarrow v^2=\frac{2mghr^2}{mr^2+I}$$ ... the trick is to pick the correct r.
The yoyo is basically rolling down the string on it's inner radius.
(Aside: This is what I mean by "show your reasoning" ... if you just memorize equations and do a bit of algebra, you will keep getting things wrong.)
When it's center of mass has a speed v, it is turning with angular velocity ... ??
Using r=0.03m, I get v=0.30581m/s. which is 0.3m/s (1sf)
If your program says that is not correct, you should check the input format: these computer things can be fussy about getting things exactly the way they expect
- does the sig fig matter for eg?
  • #38
Sorry post fan.
I got stuck on the radius of the yo yo needing to be on the very outside like a disk with a string attached.
The yo yo is indeed rotating from the distance given in the problem. If they had given the radius of the yo yo from middle to the outside the moment of inertia for the yo yo would have been too large.
My bad, as they say on the urban courts of physics
