Yo-yo's, Moment of Inertia, and Rotational Potential Energy
The discussion focuses on solving a physics problem related to a yo-yo's moment of inertia and rotational potential energy. The user seeks assistance with questions 2-5, emphasizing the need to calculate the moment of inertia for three cylinders and the importance of understanding both translational and rotational motion. Key steps include drawing a free body diagram and recognizing that tension is unknown, with the point of contact having zero acceleration. The correct order of solving the problems is crucial, as question 5 cannot be addressed without first determining acceleration from questions 3 and 4. Overall, the thread highlights the complexity of the problem and the collaborative effort to find a solution.
conrthomas
See the attached PDF document, all information is given and the help I need is on number 2-5, which is all one problem. I do already know that you have to do 2, then 5, then 3, then 4. Between 30 of my friends and I, we cannot get it.
Thanks in advance.
ok let's start with the second question
you must understand the body is doing both translational motion.
the axis here is the line along which it is rotating. it is passing through three cylinders
for a cylinder MI =(mr^2)/2
you need to calculate for each cylinder and then add these
for third and fourth questions:
when you have found the MI then:
draw the fbd...
there are two forces on the object- weight and tension here tension in unknown
you know one thing - since there is no slipping the point of object in contact with rope will have zero acceleration.
from this much information you can find tension and acceleration
you can easily solve the fifth question once you have solved the third and fourth
the order was not correct
you cannot do 5 without knowing acceleration
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
