Young's Double Slit Experiment with Single Photon Counters and Offset Mask
ivanb
I was thinking about this. Setup a Young's double slit experiment as follows.
Single Photon Source /Pulsed Photon source -> Single Slit-> Mask with two Slits (Slit 1 and Slit 2 )-> Detection plane consisting of many single photon counters.
I am assuming it's possible to detect the correlation between emitting of the photon/electron and arrival at the detector. So essentially knowing the time of flight as well the position where the photon/electron hits the screen. Not being a particle physicist maybe this all would be easier with a particle beam ?
I turn the experiment on and I would expect to build up the usual Youngs intereference pattern on my detector along with time of flight data for each event. If i then be able to rotate the mask of the two slits so that Slit 1 is closer to my detector, would i not be able to determine which slit the particle passed through? Since particles that are deflected further away from the axis of the experiment are more likely to have gone through Slit 1 and not Slit 2?
This is a very interesting idea, and in principle it could work. However, there are some practical considerations that need to be taken into account before you can actually make this experiment work. First of all, the single photon or particle source needs to have a very short pulse duration, otherwise the interference pattern will not be visible. This means that the time resolution of the detector needs to be very high, as it needs to be able to detect the arrival times of each particle with a high degree of accuracy. Furthermore, the mask needs to be precisely aligned, as even a small mis-alignment can significantly affect the interference pattern.Finally, a very important consideration is the number of particles that you would need to collect in order to reliably measure the interference pattern. This number depends on the level of noise present in your system, so it is best to simulate the experiment beforehand to get an accurate estimate. If the number of particles needed is too large, then the experiment might become unfeasible.
