Young's light interference experiment
In Young's double slit experiment, the brightest fringe occurs at the center due to the superposition of a double slit interference pattern and a single slit diffraction pattern. The single slit diffraction pattern is inherently brightest at the center, with brightness decreasing as one moves away. While all fringes experience constructive interference, the intensity varies, leading to a reduction in brightness for fringes further from the center. The central bright fringe results from full constructive interference, while the outer fringes experience varying degrees of destructive interference. Understanding the interplay between these patterns clarifies why the central fringe is the most luminous.
jaumzaum
Why, in the Young's double slit light interference experiment, the medium fringe is the brightest and the other ones go reducing its bright as you moves away the center, if they all suffer the same constructive interference.
Please explain this to me, I have this doubt it's been a month and I cannot find any article or site that says anything about this.
Thanks
John
Science news on Phys.org
The full pattern seen from a double slit is a double slit interference pattern superposed on top of a single slit diffraction pattern. It's the single slit diffraction pattern that is brightest at the center and reduces in brightness as you move away from the center.
Check this out: Double Slit Diffraction
They do not all suffer the same constructive interference. The pattern goes from constructive interference at the center of the bright spots to destructive interference as you move away. The center of the dark spots have full destructive interference and the center of the light spots have full constructive interference.
So why in the single slit, the constructive fringes bright reduces as you goes away from the center?
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
