Young's Modulus (tensile Test)
The discussion centers on calculating Young's Modulus using a tensile test with given parameters for black mild steel and bright steel. The original cross-sectional area is 24.63 mm², with an original diameter of 5.6 mm and a gauge length of 35.07 mm. The user is struggling to achieve the correct value, obtaining 19.9 GPa but suspects a factor of 10 error. A suggestion is made that either the gauge length should be 350 mm or the extension should be 0.025 mm to correct the calculation. The conversation emphasizes the importance of accurate measurements in determining material properties.
Joe123
Original Cross sectional area 24.63mm^2
original diameter 5.6mm
Gauge length 35.07mm
Extension length of the point on the graph i have chosen: 0.25mm
Force at 0.25mm extension 3500N (or 3.5KN)
(F/A0)/(ΔL/L)
I have gone through numerous attempts trying to solve this equation, i believe i am a factor of 10 out, as using the above equation gives me 19.9 GPa but i can't for the life of me figure out where i am missing the extra digit.
The materials are black mild steel and bright steel.
I've uploaded the graph in case I've stated anything wrong, looking at the first 3 specimens. (second graph is irrelevant)
Hi Joe welcome to PF!
Looks like yes, you are off by a factor of 10, so either your gauge length should be 350 mm or the extension is .025 mm. Perhaps the problem is mistyped.
