Young's slit experiment with single photons
81 replies · 9K views
Marilyn67
Hello,
I have a little problem understanding Young's slit experiment with single photons :
I have understood for a long time that each photon impact on the screen corresponds to a photon sent by the source, and that, if we don't try to find out by which path the photon has passed, of course, each impact of photon contributes to gradually draw an interference pattern, ok.
My problem comes from the description that is often made in popular science articles :
We are told : "The photon interferes with itself", which amounts to saying that the wave function of a photon has passed through the 2 slits.
The problem is this :
If we move away from the median line between the 2 slits, the distance traveled by the photon from one slit is different from the distance traveled by the photon from the other slit.
I conclude that this (single) photon can't interfere "with itself" since when the complementary part of the photon arrives on the screen, the first part has already produced an impact since it arrives ahead of the complementary part (a single photon can't produce 2 impacts, it's impossible, since there is reduction of the wave function at the first impact).
Necessarily, I tell myself that to have an interference, at different distances, (all over the screeen) it's "different" photons that interfere with each other, because the sending rate of single photons is sufficiently fast. That's right ?
If yes, then I deduce that with a much slower rhythm (we wait for the impact of a photon on the screen to send the next one), the pattern is no longer an interference pattern but a pattern of classical diffraction. That's right ?
This seems consistent with the idea that in this very specific case, by knowing at what "moment" a photon arrives, we can deduce what path it has actually traveled by deducing the distance it has traveled from time (potentially measurable, even if it is not measured) and C. (d=C.t).
How does the mathematical formalism of quantum mechanics manage to predict this phenomenon, predictable but a priori surprising since there is no longer a single ψ wave function, but as many ψ wave functions as photons ?
I guess this process (changing pattern with a very slow rate) doesn't work with electrons because the speed of an electron is fundamentally undetermined before measurement, whereas the speed of a photon in vacuum is always fundamentally determined (C), if I'm not talking nonsense. (?)
Is there a reasoning error somewhere ?
Above all, tell me if I wrote one or more nonsense in my message, it's very important for me :wink:
In advance, thank you for your answers.
Cordially,
Marilyn
Nature simply doesn’t care about your conclusion. As beautiful and certain as it seems to you, it isn’t the way she works. A single photon does in fact interfere with itself, in the usual meaning of the phrase.
Under your own justification for why a photon cannot interfere with itself, it would be even more impossible for other photons to interfere. If the picoseconds you are talking about in your concern make a difference, then the much longer time between photons will be a huge issue.
Reply
Hello Dale,
Thank you very much for your very quick response, but I don't understand.
How is interference possible if the 2 complementary parts of the photon don't coincide at a specific place and time ?
If I take an extreme case and only send a photon after one second ore one minute ?
There must be a limit, right ?
I may have misunderstood your answer.
Cordially,
Marilyn
This is another example for the harm done by still writing bad introductions to quantum-mechanics textbooks by using the outdated picture of photons as some point-particle like entities representing the electromagnetic field. That's utterly wrong. A photon is just a one-quantum Fock state of the quantized electromagnetic field. You should think of it as a wave rather than a point-particle like object.
The phenomenolgy simply is that if you do the double-slit experiment with a single photon the interference pattern of the corresponding electromagnetic wave (i.e., the energy density of this em. wave at the observation screen) provides the probability distribution for detecting a photon at a given place on this screen. To see this probability distribution in your experiment you have repeat it very often, i.e., accumulating many single photons going through the double slits.
With this simple picture all the apparent difficulties in understanding, why single photons show interference phenomena as do classical electromagnetic wave in this specific sense of probabilities for detecting a photon at the screen, are gone.
Reply
  • Love
The photon is not a classical point particle and does not follow a classical trajectory. Or, in this case, does not follow the superposition of two classical trajectories.
Instead, there is a certain probability amplitude for detection of a photon at a given point at a given time. Moreover, there is no classical certainty about when a photon is emitted from source. There is, therefore, a nonzero probability of the photon detection event at points that are not equidistant from the slits.
Reply
  • Love
PS in basic terms the uncertainty in time means there is an overlap between the times for each component of the superposition when the probability amplitude is nonzero for a given point on the detection screen.
Reply
  • Love
Although no substitute for a serious introduction to quantum electrodynamics, you will find Feynman’s layman-friendly and almost math-free book “QED: The strange theory of light and matter” helpful.
Reply
There are no two complementary parts.
A photon is a specific state of the electromagnetic field. Such states are spread out, and more specifically the position operator cannot even be defined for them. Saying that it has two parts and that those two parts are in different places is simply not related to how these states actually behave.
A single photon is the entire state, not just a part of the state. The state itself is a wave, and it behaves as a wave does, including exhibiting interference. The math is solid, the theory is solid, and the experimental evidence is solid.
Reply
Thank you all for your very concise answers.
Yesterday evening again, I would have certified that I was right, especially since the idea was consistent with the fact that the knowledge of the path always coincides with a classic pattern and vice versa.
So this unavoidable condition is always respected here, except that the opposite is happening and that we cannot therefore know the path traveled in this way.
You are absolutely right, and when I ask myself a quantum question, I always think first in terms of waves, those that we use in the classical field to have the best possible intuition at the start, and then, I think about what quantum mechanics could bring as a change.
I realize that I was wrong with quantum mechanics.
The explanation is there...!
I really never thought of that.
This explains why we can't know what path has been traveled, because we don't know "t".
This is the clearest and most convincing explanation !
This "overlap" makes me understand why doing the same experiment on an astronomical scale, such as the Earth-Moon distance for example, and decreasing the photon firing rate would not change anything on another scale of time and space ! (it was a question I had in mind and I don't need to ask it anymore).
Thank you, I took good note of it !
I would like to tell you all, that if I asked you this question with the experience of Young's slits, it's because there is an idea that I have had in mind for some time and I still have to think about it before to submit it to you (it's much more complex and it involves things that are apparently well established in quantum mechanics).
As soon as I put it on paper, I'll open a new topic in this section, and I'll put the link in this topic to make sure you don't miss it, because your knowledge is really precious to me !
I'm really curious to know what you will think of it because I can't find the answer anywhere and it seems that the experiment has never been tried in this way.
See you soon,
Marilyn
Sorry Dale, our messages crossed.
I don't doubt it for a second, and I thank you for all the knowledge you bring to me here.
I have an experimental protocol in mind, precisely exploiting our knowledge of quantum mechanics, and I don't know what to think of it for the moment.
As said before, I still have to think about it before submitting it to you, and I really don't know what to think of it for the moment with my modest knowledge.
Have a good evening,
Marilyn
Hello,
As promised, I'm coming back to you :wink:
I made a schoolgirl mistake in my protocol, and this one is in the trash...:bow:
Sorry for my last off-topic post, that was stupid of me.
@PeroK: Thanks for the very clear explanations and I understood this problem of indeterminacy on when the photon was emitted and the resulting non-zero probabilities on non-equidistant points, but a bigger problem has been bothering me ever since yesterday.
Ok, but my problem is this, now :
We can easily do the equivalent of Young's slit experiment by replacing it with a Mach-Zehnder interferometer.
The advantage is to be able to have a very short path on one side, and a very very long one on the other (detour with mirrors, fiber optics, and even also (why not) materials that slow down light to a snail's speed).
Let's go crazy and imagine a path of 1 meter on one side and (for example), the Earth-Moon distance on the other side (I'm taking an extreme example).
The time gap is huge !
My "classic" intuition with a continuous laser tells me that I would have interference. Ok.
But if now I take single photons again (example, one photon per second), I agree that I still have an uncertainty on the emission time as with Young's slits, but I have a large trust interval beyond which I am certain that photon a was not emitted, with the counter and my clock in front of me, right ?
If I take up the concept of a wave, I have a single wave which passes through the short path and a single wave which passes through the long path.
The uncertainty as to when the emission is still there, but that's ridiculous compared to the large trust interval where I'm certain the photon hasn't been sent, so the probability of there being an overlap is zero, no ?
How to explain that the two waves interfere with such a degree of trust over such a large difference in duration, greater than 1 second here ? :oldconfused:
I confess that I am lost !
Thank you in advance for your always very concise answers.
Cordially,
Marilyn
You're assuming that they do--that is, that if we did the Mach-Zehnder interferometer experiment as you describe, with path lengths differing by many orders of magnitude, that you would still get the same result. But actually that is not what QM predicts! See below.
Only if the laser is on for the requisite amount of time--heuristically, long enough for the light travel time over both path lengths to elapse.
But in the MZI scenario you describe, that is not the case--at least, that seems to be the point of your formulating the scenario. And if it is not the case, then the MZI result will not be the same as the usual result: there will be a nonzero probability for the photon detector on the output arm that normally never detects a photon in the standard MZI experiment, to detect a photon.
Reply
Hello @PeterDonis,
Thank you for your quick reply !
PeterDonis said:
You're assuming that they do--that is, that if we did the Mach-Zehnder interferometer experiment as you describe, with path lengths differing by many orders of magnitude, that you would still get the same result. But actually that is not what QM predicts! See below.Only if the laser is on for the requisite amount of time--heuristically, long enough for the light travel time over both path lengths to elapse.
So, if I understand correctly, in this case, with these orders of magnitude, we will have a classic diffraction pattern ?
My first intuition was therefore quantitatively wrong, (Young) but qualitatively, if we use a Mach-Zehnder interferometer, with two arms whose length can be modified at will, can present either an interference pattern or a classical pattern of diffraction, depending of the case...
Without going into big calculations, do you know from what approximate ratio a difference is obtained ?
Cordially,
Marilyn
This will happen when the path difference exceeds the coherence length. So it will depend on the source used and the setup of the optics.
Reply
What experiment are you talking about? A Mach-Zehnder interferometer does not give a diffraction pattern. You have two photon detectors in the two output arms of the second beam splitter; in the normal MZI setup, where the beams in both arms coming into the second beam splitter are exactly in phase, only one detector will fire. Putting something that shifts the phase into just one arm will give a nonzero probability for the other detector to fire; but drastically increasing the length of one arm will also do that.
Reply
Thanks @PeterDonis for your response,
I misspoke.
I speak of course from experience with an MZI.
Yes, when I was talking about diffraction pattern, I made a misstep.
I should have said simply that there was no interference pattern.
So you are confirming to me that in this extreme scenario (#11), we no longer have an interference pattern but a diffuse pattern ?
Cordially,
Marilyn
What kind of detectors does the MZI that you have experience with have? The typical description I see has photon counters at each output arm, which don't show patterns at all, they just give a count of photons. That is what I have been describing up to now.
If you have some sort of "pattern" detector at each output arm, in a standard MZI with nothing in each arm and each arm of equal length, I would expect to see a bright spot on the detector at one output arm (call this detector A) and nothing at all on the other detector (call this one detector B). There won't be any sort of "pattern" because there is nothing to form one: you just have light all in phase coming out one arm only.
In the MZI you describe, what you would expect to see will depend on how long you leave the laser on. If you leave the laser on for a long time (heuristically, significantly longer than the difference in light travel times between the arms), you would expect to see the same output as for the normal case above, except that at the very beginning and the very end of the experiment you might see the spot at detector A dimmer than the above and a dim spot (instead of nothing) at detector B. Heuristically, these differences at the beginning and the end are the times when there is only laser light in one arm (only the shorter arm at the beginning, only the longer arm at the end).
If you leave the laser on only for a short time (heuristically, significantly shorter than the difference in light travel times between the arms), you would expect to see a pair of dim spots, one each on detectors A and B for a short time, then a short period of darkness on both, then another pair of dim spots, one on each detector, for a short time. Heuristically, these correspond to the time when there is laser light only in the shorter arm, and only in the longer arm. The shortness of the laser on time means there is never a time when there is laser light in both arms.
Note that all of the above also assumes that the difference in path lengths between the arms is an exact multiple of the laser light wavelength, so that when there is light in both arms, the light in both arms is exactly in phase when it reaches the second beam splitter.
Reply
Hello Dale,
I understood, but I was hoping for an example with numbers.
Example :
With a 1 meter arm and a 2 meter arm, a wavelength of 532 Nm, is it possible ?
At what rate of sending photons should we go down to have a diffuse pattern instead of an interference pattern in this case ?
Cordially,
Marilyn
There is an interesting video, discussed in the thread
https://www.physicsforums.com/threads/how-big-is-a-photon-interesting-video.1005059/
To achieve a coherence length of one meter is quite a challenge, requiring a very stable laser.
The demonstration is interesting because the intensity is reduced so much that there is only one photon in the apparatus at any time. (Extending this to the moon appears to be completely out of the question!) :smile:
Reply
Thanks @PeterDonis,
I understand what you are saying and I agree with you.
You ask the right question, I lack rigor !
I find out that I don't even know myself, but I'm sure I've seen it somewhere on arXiv !
When my PC crashed, I didn't save these documents !
It seems to me (?) that to form a visible pattern (spread in space), some experimenters used detectors composed of a lens (or a prism?) with a kind of CCD screen behind, like a camera, but I'm not sure.
Do you know how they do it ?
Is it possible to have a spatially distributed pattern on a screen on either side of the second semi-reflecting blade this way ?
Your help is invaluable to me !
Cordially,
Marilyn
Whatever single photon source you have, the manufacturer’s documentation should have that information. I don’t. If it is a custom-built source then you would need to measure it yourself.
However, this ties back into @PeroK 's comments above. To get a longer coherence length means a smaller linewidth. A smaller linewidth means that the time uncertainty is larger. The two are unavoidably paired. You will find no conflict. If you make the path length very different then the only photons that will be able to self-interfere will be exactly those where the time uncertainty is large enough.
Reply
Hello @WernerQH ,
Thank you for this very interesting link !
I just watched this video, and I had to take breaks !
Great video, great editing explained in detail and great explanations from the author !
This video brings me answers but asks me others !
I will have to read all the comments to try to see more clearly.
In particular, if I understand correctly, the laser + the filters are not a real source of single photons and there are always interferences.
Conversely, a fluorescent lamp is not coherent and there is never any interference.
So the error that was diagnosed by the Oxford Physicist seems to be the use of filters to produce single photons.
On the other hand, the video doesn't say what would happen with "real" single photons (from very expensive sources in laboratories such as those of Alain Aspect) by increasing the distance between the first experiment and the second and, the case where applicable (here), at what distance an interference pattern is changed into a pattern without interference.
Anyone have the answer ?
Cordially,
Marilyn
The answer is that there is no "the" answer. Each source has its own coherence length. You will have to find that either experimentally or in the manufacturer's documentation.
Reply
This illustrates one of the dangers of using pop science videos. As it is stated, the quoted sentence is false. What the actual math says is significantly different: "the intensity is reduced so much that the expectation value of photon number is less than one". Lasers emit coherent states, which are not eigenstates of photon number, so you cannot say "how many photons" are in the apparatus at a given time.
Reply
In the sense that this kind of source emits coherent states, which are not eigenstates of photon number, yes.
No. With a laser + filters source, there are still conditions that have to be met to get an interference pattern (as opposed to just a diffuse spot on the detector). It doesn't always happen.
Not quite. A fluorescent lamp emits a coherent state of the EM field; it just has a much shorter coherence length than a laser. In fact, pretty much any common light source emits a coherent state of the EM field, since that kind of state is the closest thing in quantum field theory to a classical EM field state. The main difference with lasers is having a coherence length long enough to enable meaningful interference phenomena to be easily detected.
More precisely, for most light sources it is very difficult to set up an experiment that will detect meaningful interference phenomena.
Reply
There is always interference, but the phase relations between the waves may not be stable enough to lead to visible interference fringes. They tend to be washed out. You can produce interference patterns also with a fluorescent lamp. If you pass its light through a Fabry-Perot filter, for example, the coherence length can be as long as ## 10^4 \lambda ## when the filter's bandwidth is ## \Delta \lambda / \lambda = 10^{-4} ##.
I don't know what "real" single photons are. You always have to wait some time for a photon to be produced, although there are of course experiments where they are created very quickly. The photon concept applies to the absorption and emission of light, which occurs only in "lumps" having energy ## E = h\nu ##. The propagation of light, however, is well described as a wave phenomenon (Maxwell's equations).
Reply
If you don't observe any interference, you can't say there was interference, at least as far as experimental results are concerned.
If you are basing your claim that "there is always interference" on some theoretical model, please show your work.
Reply
This is only correct for certain kinds of emission and absorption processes, not all of them. It is not correct for emission of light a laser, for example, since, as has already been noted, the EM field state emitted by a laser is a coherent state, and a coherent state is not an eigenstate of photon number.
Reply
Even though laser light does not have a defined number of photons, it doesn't change the fact that
Reply
Since a laser emits a coherent state, how is the quoted statement a correct description of the laser emission process?
