Are Zero's and Roots the Same Thing?
  • Thread starter Thread starter viet_jon
    Roots
Zeros and roots are often considered synonymous in the context of polynomials, as both refer to the solutions of the equation. However, a distinction is made when discussing functions, where "zeros" specifically refer to solutions of the equation f(x) = 0, while "roots" pertain to solutions of an equation in general. Some participants argue that using the terms interchangeably is imprecise, noting that even reputable sources like Wikipedia can be inconsistent. The discussion highlights the importance of clarity in mathematical terminology. Ultimately, while zeros and roots can overlap in meaning, their usage can vary based on context.
viet_jon
zero's and roots...
Zero's are the same thing as roots, correct?
I have a question where a) askes what's the zero's. Then b) asks what are the roots.
pretty sure it's the same.
i think when reffering to polynomials zeros and roots refere to the same thing, however when referring to functions i think that we cannot reffer to it as the roots of a function, but only we should referr as the zeros of a function.
I am not quite sure though!
you're right they are the same:
http://en.wikipedia.org/wiki/Root_(mathematics)
No, they are not the same. Not if you are being very "correct".
A root of an equation is any solution to that equation.
A zero of a function, f(x), is any solution to the equation, f(x)= 0.
I see that Wikipedia says the opposite, saying that a "root of a function" is the same as a "zero of a function" but I think that is very sloppy terminology. Unfortunately even mathematicians get sloppy sometimes.
i mean what you are saing i think you are right...
marco
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
