Japan Earthquake: nuclear plants Fukushima part 2
This thread discusses the recent magnitude-5.3 earthquake that struck Fukushima, Japan, and its implications for the nuclear power plant affected by the 2011 disaster. The conversation includes updates on the plant's condition, ongoing monitoring efforts, and the challenges faced by Tepco in managing the aftermath of the earthquake and previous incidents.
  • Experimental/applied
  • Some participants share news articles about the earthquake and its impact on the Fukushima nuclear plant.
  • Concerns are raised about the structural integrity of tanks at the plant, with reports of loosened bolts and corrosion potentially leading to leaks.
  • Participants discuss the need for similar structures for fuel removal at Units 3 and 1, contingent on the success of operations at Unit 4.
  • There are questions regarding the discrepancies in Tepco's reports about groundwater flow and contamination levels, with some participants expressing skepticism about the accuracy of the information provided by Tepco and the government.
  • Links to various news articles and updates from Tepco are shared to provide context and ongoing developments related to the plant's status.
Participants express a range of views, with some agreeing on the need for further monitoring and structural assessments, while others question the reliability of Tepco's information. The discussion remains unresolved regarding the implications of the earthquake and the adequacy of Tepco's responses.
Participants note limitations in the ability to inspect all tanks and the challenges in managing contaminated water, highlighting the complexity of the situation and the ongoing risks associated with the plant's operations.
  • #1,771
Sotan said:
I hope that little piece of debris is not being considered representative for the whole deposit at the bottom of the PCV - what was it, 200 tons plus?
Fukushima Daiichi Unit 2 was a BWR/4 type with a gross electrical power generation of 784 MWe gross, 760 MWe net (so about 24 MWe used by the plant). Units 2, 3, 4 and 5 were much the same design, and apparently not uprated.
https://en.wikipedia.org/wiki/Fukushima_Daiichi_Nuclear_Power_Plant
The Fukushima BWR/4s would have 560 assemblies in the core, and I believe each assembly has about 180 kg of fuel (which could be in terms of U metal), about about 200 kg of fuel (UO2) + structural materials like Zircaloy-2 (~46 kg Zr-2, not including channels/shrouds), stainless steel (~6.7 kg), and Inconel (incidental).
Estimating about 270 kg/assy x 560 assy/core, one has 151,200 kg (or 151 tonne) in the core, excluding core support structures.
The limited sampling can only give a clue as to what might have happened. It there is little or no U (and Np, Pu), then one is left with mostly stainless steel and/or Zr. If there is little or no Zr, then one is left with stainless steel. All metals are probably oxidized. I think they will look for metals that are characteristic of fuel, cladding and stainless steel structures, in order to determine where the sample originated, or what it represents. If they find some fission products, e.g., Ru, Rh, . . . . , then that would be from the fuel.
More samples are needed, but at least, TEPCO was successful in retrieving a sample, however small.
FYI - Comprehensive Analysis and Evaluation of Fukushima Daiichi Nuclear Power Station Unit 2
https://www.tandfonline.com/doi/full/10.1080/00295450.2019.1704581#abstract
  • #1,773
They completed the second "fuel debris sampling" operation.
Link to report
I don't want to sound disappointed but... This time it seems they retrieved 0.2g.
  • #1,774
New report on Tepco's Fuel Debris Portal site, about the first results of the analysis of the second sample (May 29).
>> Link
  • #1,775
New post on the "Fuel Debris Portal" site.
"2025.7.29 Fukushima Daiichi Nuclear Power Station Unit 3 Design Deliberation for Fuel Debris Retrieval Method"
There are two links at the bottom of that article, one is the report of a sub-committee regarding fuel debris retrieval (published in March, unfortunately only in Japanese) and the second is TEPCO's own report on this matter, submitted to the sub-committee on July 23 (in English).
"At present, it is estimated that approximately 12 to 15 years will be necessary to prepare the top and side access points regardless of which option (North-South work platform or the East-West framework) is employed. (However, the results of this deliberation are based on the assumption that progress will proceed as expected, even though there remain issues that require additional review.)"
  • #1,776
  • #1,777
Thanks for that link, @Sotan !
Very interesting and the graphics in the report are excellent.
  • · Replies 14K ·
473
14K
4M
49K
16K
  • · Replies 16 ·
  • · Replies 763 ·
279K
