3D printing a gear box, I'm having some problems with the gears getting stuck.
The discussion revolves around issues encountered in a 20:1 gearbox prototype where gears frequently get stuck. The user suspects that the alignment of the gears in a straight line and the design choice of having shafts as part of the base may contribute to the problem. Suggestions include grinding a chamfer into each gear tooth to improve engagement and adjusting the 3D printer settings for better accuracy, as low-cost FDM printers can produce imprecise parts. Additionally, using a gear template generator from woodgears.ca is recommended, although caution is advised regarding the accuracy of the gear profiles. Overall, the shape and alignment of the gears are critical for ensuring smooth operation in the gearbox.
dennis_n
I'm building a simple 20:1 gearbox prototype with 2 compound gears in a row connecting to a third small gear at the end. My goal is to multiply the rotational speed of the small gear.
They are all engaged on a straight line. But for some reason they get stuck most of the time.
I'm trying to figure out what the problem may be.
I had to make the shafts part of the base of the gearbox (cause my printer doesn't print support material, and I wouldn't be able to print a gear on top of a shaft), so each gear has a hole and it spins freely around the shaft. I don't know if that is less efficient than the shaft being part of the gear. I'm not an engineer to know those kinds of details.
I'm also wondering if all the gears being on a straight line, somehow causes them to lock in place most of the time.
I was hoping someone might have an idea.
The shape of the gear is key for proper entrance and exit of teeth.
1. Have you tried grinding a chamfer into each tooth?
2. 3D prints are notoriously inaccurate. especially with low cost FDM machines. play with the feed rate of your plastic. Try to get the head a close to the part as possible. If possible heat the the build area while printing. This will make the deposition more uniform.
3. Try using the free gear template generator offered by Mattias Wandel at woodgears.ca: http://woodgears.ca/gear_cutting/template.html
A caution about using Wandel's gear profiles. They are quite good enough for wooden gears, which is the purpose for which he markets his software, but I don't believe that they are true involutes, as far as I can tell. I have had some correspondence with him, and he is guarded about what he will reveal, but it appears that he has made some approximations that will result in something other than true involutes.
OldEngr63 said:
A caution about using Wandel's gear profiles... it appears that he has made some approximations that will result in something other than true involutes.
Good to know OldEngnr63...
You could always do it by hand, but Wandel's look better than the gear primitives found in most 3d software I have encountered. For a hobby project it's worth a shot.
The resulting gearbox has very little side to side movement. Usually you have to compensate for clearance and so doing will make an inefficient gear box whereby the gears move side to side a lot.
Regards
John
sticker printing
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
