Calculating Amperage from a 3 Farad Capacitor
  • Thread starter Thread starter ramonegumpert
    Amperage Capacitor
To calculate the amperage from a 3 Farad capacitor, the relationship is defined by the formula I = C * (dV/dt), where I is the current, C is capacitance, and (dV/dt) is the rate of voltage change. The amperage is influenced by the voltage and resistance in the circuit rather than just the Farad rating. Charging a lithium-ion battery with a capacitor may affect its lifespan, with constant DC voltage typically being better for battery health. For free samples of super capacitors, contacting manufacturers directly is advisable. Understanding these principles is crucial for effective capacitor use in circuits.
ramonegumpert
Dear Experts
I bought some 3 Farad electrolytic capacitors at 2.5v each.
I am wondering how much amperage can i get from 1 such capacitors if charged fully and then discharged fully?
I think this is measured in Amp-hours.
Is there a formula to derive the amperage from the capacitor's farad rating?
Please recommend where I can get free samples of super capacitors or boost capacitors.
Thanks a lot :)
Best regards
Ramone
You can find what you want to know from some of the most basic electrical laws and formulas. You know, the basics like Q=CV, definitions, etc. When you fully discharge a capacitor from fully charged the current (amps) will be constantly changing. Not sure what you are trying to do here but that is something to think about. BTW, what you call amperage is generally called current and is measured in amperes. Amp-hours is usually something that is associated with batteries. A battery is able to produce a given current for a specified time and the product of those two is amp-hours. A battery that is rated for 100 amp hours can do 10 amps for 10 hours or 5 amps for 20 hours.
What will your capacitor be charging? Any time you change the load (resistance)...you just changed the RC constant.
I'm assume you are using a battery to charge it? Also assuming you are talking about a cap in series with a resistor (load)
If so...just google "RC constant formulas"..."or RC transient"...and plug and chug for the current.
The formula for use of battery looks like this:
i(t)={[V-Vc(0)]/R}*e^((-t/(RC))
V is your voltage source...and Vc(0) is your initial charge on your capacitor.
If you are charging cap...Vc(0) will just be zero...
If you are discharging the cap...disconnect the battery...and ignore the V in your formula. I'm assuming Vc(0) will be 2.5 volts in this case.
Hello Averagesupernova and Psparky
Thanks very much for your replies and advice .
Psparky guessed correctly. I am trying to charge a lithium ion battery.
Will cyclic discharging of the capacitors to the battery cause the battery to age faster or is constant DC voltage slow charging better for the battery life?
Thanks!
regards
Ramone
Dear Ramone,
Thank you for your inquiry regarding calculating amperage from a 3 Farad capacitor. The amperage from a capacitor is not directly related to its Farad rating. Instead, it is determined by the voltage and resistance in the circuit. The formula for calculating amperage in a capacitor is I = C * (dV/dt), where I is the amperage, C is the capacitance in Farads, and (dV/dt) is the rate of change of voltage over time. Therefore, to determine the amperage from a 3 Farad capacitor, we would need to know the voltage and resistance in the circuit.
As for obtaining free samples of super capacitors or boost capacitors, I would recommend reaching out to manufacturers or distributors directly. Many companies offer free samples for testing and evaluation purposes.
I hope this information helps. Please let me know if you have any further questions.
Best regards,
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
