How many combinations can be created with 2 letters, 2 numbers, and 2 letters?
The discussion focuses on calculating the total number of unique combinations for a code consisting of 2 letters, 2 numbers, and 2 letters, using 24 letters and 8 numbers. The formula provided indicates that there are 21,233,664 possible combinations. The user aims to generate 2.5 million unique codes but acknowledges the potential for duplicates in random generation. They plan to remove duplicates from the generated codes to meet their unique code requirement. The conversation also touches on the concept of randomness and the need for a method to ensure unique selections.
reldridge
I am creating a random combination(code) for a client. I need to see what the total number of combinations there can be.
Please let me know if I am using the wrong word Combination vs Permutations.
Formula:
2 letters + 2 numbers + 2 letters
example: TR12FR
The random letters are taken from 24 values:
ABCDEFGHJKLMNPQRSTUVWXYZ
The random Numbers are taken from 8 Values:
23456789
Any help would be greatly appreciated.
Thanks
Ryan.
Mathematics news on Phys.org
combination is right you're selecting letters, numbers and more letters:
Choices for each character of your 6 charcter code:
24 * 24 * 8 * 8 * 24 * 24 = total number of codes possible
Now if these could be rearranged then you'd have to worry about permutations to elimnate repeats in your counts.
Thank you -
So de-duping these down to create 2.5 million unique codes using this formula will not be an issue, sense there are 21,233,664 possibilities.
Well sense this is just a random generator out of excel the possibility of it creating a duplicate is there, so i will need to just remove dupes, or nth select down to 2.5 million unique codes.
Just needed to make sure that the 6 digit using that formula could create that many unique codes.
reldridge said:
Well sense this is just a random generator out of excel the possibility of it creating a duplicate is there ...
So you have a belief that "true" random would not include any dupes?
How would you create 100000 consecutive random numbers from 1 to 100 ?
this reminds of how new programmers used to construct a deck of randomly sorted cards.
generate a number from 0-51 check if its present in the crd deck array if so then generate another.
The better approach is to generate a sorted sequence of cards into an array and then to randomly shuffle two cards by selecting two indexes at random and swapping the cards.
No belief, was just stating that there could be duplicate codes during the random selection and i would need to remove the duplicates until reaching my goal of 2.5 unique codes...
Thanks for the help.
