How do I find the work function of a metal using black body radiation?
The discussion focuses on finding the work function of a metal using black body radiation principles. The problem involves calculating the initial and final temperatures of a black body based on its peak emission wavelengths and the increase in total radiation. The user initially struggles with applying Stefan’s law and Wein’s displacement law correctly, leading to discrepancies in their calculations. The correct approach involves using Wein’s law to relate temperature and wavelength, ultimately deriving the energy of incident radiation. The conversation highlights the importance of accurately applying physical laws to solve problems in thermodynamics and photoemission.
Amith2006
1)The peak emission from a black body at a certain temperature occurs at a wavelength of 9000 Angstrom. On increasing its temperature the total radiation emitted is increased 81 times. At the initial temperature, when the peak radiation from the black body is incident on a metal surface, it does not cause any photoemission from the surface. After the increase of temperature, the peak radiation from the black body causes photoemission. To bring these photo electrons to rest, a potential equivalent to the excitation energy between n=2 and n=3 Bohr levels of Hydrogen atom is required. Find the work function of the metal.
According to Wein’s displacement law,
[lambda1(max.) x T1] = 2.898 x 10^(-3) metre-Kelvin
According to Stefan’s law,
Energy of incident radiation(E2) = (sigma) x T^4
I have doubt only in the first part of the problem. So I haven’t worked out the entire problem.
I solved it in the following way:
Let T1 and T2 be the initial and final temperatures respectively. Let lambda1(max.) and lambda2(max.) be the initial and final wavelengths respectively. Let E1 and E2 be the initial and final energy of the radiations respectively.
E is proportional to T^4
Hence,
E1/E2 = [T1/T2]^4
Therefore,
T2 = 3T1 {since given that E2/E1 = 81}
Hence, T1 = 3220 Kelvin
Hence, T2 = 3T1 = 9660 Kelvin
= 5.67 x 10^(-8) x (9660 x 10^(-10))^4
= 4.94 x 10^(-32) Joules
The solution given in my book is as follows:
Hence,
E1/E2 = [T1/T2]^4
Therefore,
[lambda(max.) x T] = constant
i.e. [lambda1(max.) x T1] = [lambda2(max.) x T2]
lambda2(max.) = 3000 Angstrom
Energy of incident radiation(E2) = hc/ lambda2(max.) = 6.63 x 10^(-19) Joules
Why do I get 2 different answers?
You assumed a lot of things when you use Stefan's Law: that it was a perfect blackbody, and the flux was uniform.
The solution your book gave is correct because it does everything through Wein's Law, and then uses the fact that E=hv=hc/lambda.
Thats cool! Thanks.
