The set of ring automorphisms is an abstract group under composition
catcherintherye
Aut(R) denotes the set of ring automorphisms of a ring R Show formally that Aut(R) is a group under composition.
I Have a very similar question to which I have the solution viz
Aut(G) denotes the set of group automorphisms of a Group G, show that Aut(G) is a group under composition.
Proof Let a,b: G -> G be automorphisms
then a\circ b: G \rightarrow g is also an auto
(a\circ b)(xy) = a(b(xy))=a(b(x)b(y))= a(b(x))a(b(y))
=(a\circ b)(x)(a\circ b)(y)
so a\circb is a homomorphism
it is also bijective since a,b are bijective
\circ: aut(G)\times aut(G) \rightarrow aut(G)
is automatically associative (because comp of mappings is associative)
As identity in Aut(G) take Id_g:G \rightarrow G
finally inverses
Let a: G --> G be an auto
then a^-1:G -->G is atleast a mapping and bijective
need only show
a^-1(xy) = a^-1(x)a^-1(y)
let x,y \in G
choose c,d \in G : a(c)=x, a(d)=y
a^-1(xy) = a^-1(a(c)a(d))=a^-1(a(cd)) = cd= a^-1(x)a^-1(y)
q.e.d
...the proof for rings is essentially the same right? The only thing that concerns me is the last part(above) since we used the fact that every element has it's inverse in a group but we don't have that in a ring...:confused:
Where have you used that fact?
ok so i haven't and these two proofs are essentially the same?
You did use a-1 where a is automorphism. You say you know
Aut(G) denotes the set of group homomorphisms of a Group G, show that Aut(G) is a group under composition.
Are you sure of that definition of Aut(G)? Homomorphism, in general, do not have inverses.
no I've made a mistake it's supposed to be the group of isomorphisms
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
