Final Equilibrium Temperature of Lead Shot Problem
  • Thread starter Thread starter Confused_07
    Equilibrium
The problem involves calculating the final equilibrium temperature when 0.20 kg of lead shot at 90°C is mixed with 0.50 kg of water at 20°C in an ideal calorimeter. The correct formula to use is (c*m*delta T)_lead = (c*m*delta T)_water, where delta T for both substances is expressed in terms of the final temperature T_f. To find T_f, set up the energy balance equations for both lead and water, ensuring to account for the specific heat capacities and initial temperatures. The final temperature can be solved by equating the total energy before and after mixing, using absolute temperatures in Kelvin. This approach will yield the final equilibrium temperature of the system.
Confused_07
A .20kg lead shot is heated to 90 degrees C and dropped into an ideal calorimeter containing .50kg of water initially at 20 degrees C. What is the final equilibrium temperance of the lead shot? Specific heat capacity of lead is 128 J/(kg*C), and water is 4186 J/(kg*C).
Am I using the right formula, (c*m*delta T)_lead = (c*m*delta T)_water
What is the delta T of water in this equation?
delta T_lead = (c*m*delta T)_water / (c*m)_lead
= [(4186)(.50)(?)] / [(128)(.20)]
Help... anyone?
You have to assume that the final temperature of the lead and water are the same. Write your equations in terms of this rather than delta T.
Once you have found this you can obviously work out each dT.
The equation doesn't give me the final temp of the water, so how do you set up the equations for the final temps? I'm confuse because my textbook only gives me one sample problem in it and that one gives you the final temp of the water, so the equation is simple.
Sorry if I am not seeing it...
That's correct. (Assuming you get the signs right.)
Call the final temperature T_f. Express those "delta T"s in terms of the given initial temperatures and T_f. Then solve for T_f.
Calculate the total energy at the start.
=mass lead * c lead * T lead + mass water * c water * T water
( use the absolute temperature in kelvin ie 273 + C)
At the end you have the same energy and the lead / water temperature are the same.
= mass lead * c lead * T + mass water * c water * T
Simply solve for T ( remember this is in kelvin )
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
