Fluid Mechanics Texts: White, Segel, Tritton, L&L, Aris
The discussion centers on recommendations for good texts in a specific field, highlighting several authors and their works. Segel is noted as a highly recommended Dover book that is easy to find and well-regarded. Tritton receives mixed reviews, with some finding it lacking in derivation, making it hard to generalize results. Lamb's work is described as an encyclopedia, dense and challenging to understand. Landau and Lifgarbagez are mentioned as acceptable alternatives, but Segel is preferred for its affordability. Overall, Segel stands out as a favored choice among the texts discussed.
WiFO215
What would you recommend as good texts. Here's what I've found searching the site:
White
Segel
Tritton
L&L
Aris
I don't like White very much. I can't find Segel or Tritton anywhere. Any recommendations?
Segel is a Dover book and should be easy to find. Plus, it's very good.
Tritton, I did not like so much. Not exactly sure why... it seemed that results were just provided without any derivation, making it difficult to generalize results.
Lamb is the encyclopedia. Very dense and difficult to parse.
Landau and Lifgarbagez is fine, biu Segel is less expensive.
The book is fascinating. If your education includes a typical math degree curriculum, with Lebesgue integration, functional analysis, etc, it teaches QFT with only a passing acquaintance of ordinary QM you would get at HS. However, I would read Lenny Susskind's book on QM first. Purchased a copy straight away, but it will not arrive until the end of December; however, Scribd has a PDF I am now studying. The first part introduces distribution theory (and other related concepts), which...
I've gone through the Standard turbulence textbooks such as Pope's Turbulent Flows and Wilcox' Turbulent modelling for CFD which mostly Covers RANS and the closure models. I want to jump more into DNS but most of the work i've been able to come across is too "practical" and not much explanation of the theory behind it. I wonder if there is a book that takes a theoretical approach to Turbulence starting from the full Navier Stokes Equations and developing from there, instead of jumping from...
