Connect PSpice w/ Comsol: Experiences & Examples Needed
  • Thread starter Thread starter sparky977
    Comsol
The discussion focuses on integrating PSpice with Comsol Multiphysics for simulations. Users highlight the importance of the AC/DC module in Comsol, which is necessary for effective communication with PSpice. One participant resolved their issue by reinstalling Comsol with a complete license, enabling access to the required modules. They explain that PSpice allows for the construction of electronic schemes, which can then be imported into Comsol for further simulation. This integration enables customized solutions by leveraging the strengths of both software platforms.
sparky977
I have a question regarding communication PSpice software with Comsol Multiphysics.
I was searching for some examples but I did not find anything. I would like to simulate a certain element from Spice scheme with Comsol.
Anyone have any experience with this?
I think that Comsol should have AC/DC module for communication with Spice. My version of CM does not have that module. Is it possible to get that module only?
please .. if anyone have any experience with thak kind of simulations ... I will apprechiate your help.
Can't say have experience about PSpice (other than vaguely knowing "what" it is) but have some idea about the Comsol side of things --- but what do you refer to by "element", some geometric "entity" (~model?) or does Spice have "elements" in it like in finite elements which you'd like to import? You can purchase Comsol modules separately so that's possible (the only "minor" limitation being that even single modules, at least for my wallet, are fairly expensive).
PerennialII ... thank you for your answer.
I figured out the thing I was asking.
First I had some license which does not open all modules, but I have complete version of CM on my instalation DVD. So I tryed to install once again with another license file and the software gave me te option to chose the modules which I want to install.
I was confused because I found some instructions regarding PSpice and COMSOL working together but there was stated that COMSOL communicate to PSpice via AC/DC module. But as I said before - during first installation I did not install this module. OK. this is solved now.
regarding PSpice ...
In PSpice you can construct electronics scheme, run simulation over scheme and observe the signal in every point you want.
So...the electronic scheme cosist of capacitors, transistors, diods ... different electronic elements. Let's say that you want to include some modified capacitor(this is the main reason to work with both programs) into this scheme. You construct the scheme and import it to the Comsol. In Comsol you simply construct this capacitor(you have to name the element with the same name of course) and run the simulation - in Comsol Script(or in Matlab). the script then connect both - scheme and simulation - and give you the result.
You can perform all this simulations only if you have AC/DC module because only this module understand Spice schemes.
:smile: I hope my answer was not to complicated.
Way to go! That's a really cool coupling, can do lots of really customized things and actually solve "real" problems by extracting best out of both.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
