Find the image distance - optical instruments
An object is placed 30 cm in front of a diverging lens with a focal length of 10 cm, prompting a calculation of the image distance using the lens formula. The initial calculation yielded an incorrect image distance of -15 cm due to a miscalculation in the equation. The correct approach involves recognizing that the combined terms should be calculated accurately, leading to the correct image distance of -7.5 cm. It's emphasized that rearranging equations can help predict the sign and magnitude of the result. Accurate calculations are crucial in optics to avoid confusion.
ally1h
An object is placed at 30 cm in front of a diverging lens with a focal length of 10 cm. What is the image distance?
1/f = 1/do + 1/di
I thought this was a straight-forward question:
1/di = 1/-f - 1/do
1/di = (1/-10 cm) - (1/30 cm)
1/di = -0.066 cm
di = 1/-0.066 cm = -15 cm
BUT- the answer provided to me states that the answer is -7.5cm. So what is it that I'm missing here?
Slight calculator typo
(1/-10) - (1/30) = - (1/10 + 1/30) = -0.133
Well now... don't I feel silly?
Thank you.
It's very easy to get those sort of sums wrong,
It's worth rearranging them so that you know if the answer you expect is +ve or -ve
And in a form where you can estimate the magnitude, eg (1/10+1/30) is obviously going to be a bit bigger than 1/10
