Lens can focus the light to a smaller spot by ?
Increasing the beam size of a laser before coupling it to a fiber can enhance coupling efficiency due to the relationship between beam diameter and numerical aperture (NA). A larger beam fills the lens's aperture more effectively, allowing for a smaller minimum beam waist radius. This is linked to the optical principles of Fourier transforms, where changes in beam size and divergence are interdependent. Despite a lens having a higher NA than the fiber, perfect coupling is unattainable due to the diffraction of the intensity profile. Understanding these optical dynamics is crucial for optimizing laser-fiber coupling.
cks
Lens can focus the light to a smaller spot by ...??
I learn that increase of the beam size of the laser before coupling it to the fiber can increase the coupling efficiency of it.
Can I know why is this so?
Maybe the fiber is of very small diameter, and the focal lens in front of the fiber can't focus all the laser to this small diameter. But I don't understand how increase the diameter of the laser can make the focal lens to focus to a smaller spot??
Science news on Phys.org
It has to do with the "numerical aperture (NA)" of a lens. The larger you fill the aperture of a lens the smaller the minimum beam waist radius gets.
Here is a somewhat helpful site on numerical aperture's:
http://microscopy.fsu.edu/primer/anatomy/numaperture.html
Fiber's also have a NA, and even if the focussing lens had a higher NA than the fiber's you would still never achieve perfect coupling due to the diffracted nature of the intensity profile (sorry diverting away from your question).
That's correct; by filling the aperture of the lens, the full optical power of the lens is available (the full NA is available). This may seem odd, but recall there is a relationship between the field at the front focal plane and the back pupil plane (they are Fourier transforms), so the larger the diameter (and the smaller the divergence) of the beam is in one space, the smaller the diameter and the larger divergence it has in the other.
HIhi, thank you very much.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
